The A body arm does fit down further on the stud. I used a heavy washer between the arm and the nut. Your ball stud looks completely different than the ones I've seen. The Corvette ones I have seen don't have the ridge on them and they don't have the groove on the ball. The ones I have done all used the non PS center link. Maybe the PS uses a different stud?
I drew this shim up that should work to raise the engagement point up about .25. I would make that out of full hard brass shim stock since it's so thin.
