Amazing XKE RestoMod-Sanding and more Sanding 7/15/26
ROOF REPAIR
I knew the roof wasn't perfect. All the defects were reveled after I removed the paint, applied some guide coat and block sanded it with a long board.
I suspect the roof was sat upon at some point because I had four creases, one in each corner.
These were repaired using my shrinking disc, applying heat then cooling with a wet rag.
Epoxy Primer and Body Filler
With the metal work finished, (I hope) it's on to body work.
First step was to put the car in epoxy primer. I'm using the RM EP 369, the same product that the bonnet was covered in some time ago.
Body filler choice is Evercoat Rage and Rage Ultra. I'm using a triple beam balance to accurately measure my filler to hardener 2% ratio. I've been getting some great body work tutorials on YouTube from Sylvesters Customs channel.
My first area to work on was the underside of the bonnet, probably the most difficult spot. Hard to reach, concave curve. The underside of the front pan was much easier.
Epoxy, mud mixing, first filler:
Body Working the Bonnet
With the underside of the bonnet finished, I moved on to the firewall and portions of the frame.
Next, the bonnet went back on the car so it could be completed. It had previously been roughed in years ago and now was the time for it to receive final shaping and leveling.
After finishing the front section of it, I shot it with some epoxy primer as a test, and then continued on to the rest of it:
I've amassed quite an arsenal of sanding tools, mostly sanding boards. They vary from doubled up ¼" acrylic, 1/8" ABS and 1/16" Lexan. Each has their own flex characteristics, to work the complex shape of the E-type bonnet.
In this photo, you can see the brown 80 grit and the white 120 grit:
More Body Work
After finishing the entire bonnet to 120 grit, I shot it with 2 coats of Evercoat Super Build. That will be blocked out then epoxy primer applied:
I installed some of the rubber door seals to final fit the door position. This was locked in by putting filler in the gap to prevent the door from moving while block sanding:
Cowl and doors straight edge finished and gapped:
TO BE CONTINUED
Working my way rearward:
Fitting Tail Light Housing
The tail light housing on the Series I E-Type uses a rubber gasket to cover any discrepancies between the shape of the housing and the shape of the body shell. It would also seal out any water.
I've read this gasket can be difficult to get it to fit correctly. Frankly, I think they detract from the overall look. This was my opportunity to shape the body to fit my re-chromed housing. I used both a slip of paper and a slip of cardboard to gauge my gap, bringing the space to a minimum.
A light coat of sealant will keep the water out.
Paper and cardboard feeler gauges
Final Primer
With the body work complete, it was time to remove the bonnet, boot, doors and apply the final primer.
I built a stand to support the bonnet, engineered so a person could access the inside.
The doors and boot have their own stand, also on wheels.
Masked and sprayed
After letting the body work and the primer set for 8 weeks, it was time for final sanding, 120,220 and 320, using dry guide coat between grits.
TO BE CONTINUED
Rotisserie Time
A good friend of mine built a rotisserie to restore his 1968 Jaguar OTS. He was kind enough to lend it to me. It's a well designed, well built rotisserie. Much appreciated.
To transition from the chassis table to the rotisserie, I built it one over the other:
At the front, I fabricated an adapter that connected to the bonnet hinge points.
It was easy to adjust the balance point of the body using the threaded rods at both ends. As it turned out, the position most favourable provided only ½" clearance between the rotated roof of the car and the connecting tube of the rotisserie.
600 Wet sanding, then some colour coat
Finished body working the lower section of the sills and completed the boot. Detailed the rear license plate surround and reverse light housing:
600 wet sanding doors, again, using dry guide coat:
Sprayed the underside, (floors), wheel wells, firewall and front frame section with a satin black. Also the bonnet wheel wells
Insulated the inside of the transmission tunnel, first with a CLD, Fat Mat, (constrained layer dampener), then a reflective heat shield, Boom Mat on top:
Final Prep and Masking
I had the inside of the bonnet finished in epoxy primer but decided to take it one step further and apply the RM DP236 primer. The concave panels are a bear to sand but I eventually took it to 600 wet using guide coat:
Firewall and front frame member masked:
Masked the roll bar for insurance sake:
On four wheels
Call it complete for now:
