Uncle Paul's C3
SuperBuickGuy
Pacific Northwest
Luigi thinks Paul (aka Uncle Paul) is the greatest thing since the invention of the ball. I'm not sure how much of the build I'll detail, but since asked... here we go
it's 1973 Corvette Convertible. It's in rough shape, I'd call it a great candidate for a ground up. It wasn't cheap - but it's a one-year only car (chrome rear, rubber front) a 4 speed.
As a few know, I'm apparently an evangelist for C3s. People drive my car and suddenly they want one (I obviously meet people with good taste). And truth is I wish this car was mine.
okay, so Paul bought the car and it's first major update was a Ridetech rear suspension with coil overs. Next up - he wants a BBC (as I said, good taste). Originally, he was going to build a 4 bolt 454 - but then this motor came available. I picked it up on my way back from SEMA - it's a 496 build for a boat. 10.5 compression, 2 bolt main but has a main girdle - and the debate rages on whether or not it's stronger then a 4 bolt. 4 bolts put more holes in the casting - tie all the mains together and it should be as strong or even stronger. It's way popular in boats. It's got a forged, aftermarket steel crank, great rods and forged pistons. he paid 50c on the dollar for it - and saved about 2/3 what it was going to cost to build the 468.
My personal prediction is this motors is going make manglitter out of the M2x transmission. Not a real loss because who wants those things when a Super T-10 is available? :)
We've been collecting parts, and started assembly today of the motor. Sadly this is the only update for a month because more parts won't be available for another month (mostly the tool helping him build it).
one of the missing bits was the timing chain.... I didn't think they still built single chain kits anymore... they do, they're cheap, and more importantly, available today
took the heads apart to check clearances... .080
heads are chinese copies - but decent. Something I didn't know - and should have check - the cambers were supposed to be 119cc, they measured 128.... nearly a point of compression..
so waiting for more parts. need an intake, rockers (I hate moving - I have some but who knows where they are....)
at the same time we'll update the front suspension... then see if we can't make this thing go in time for summer cruising.
one of my favorite photos, and how you birth a gear head
I've brought a lot of people into the C3 fold... funny thing is, though, I've also done the same with FJ40s and Blazers (and other squarebodies)... but what I take the most smiles from is all of those I've introduced into using Suburbans for overland camping.... there was a time when I was probably the only one - sure, people camped with them but never went head to head with the Land Rovers, '40s, and Heeps... err Jeeps.
but with that said, I think that what I tend to do is road less travelled - people scoffed at C3s when I started with them, but you knew in their mind they thought (besides "you're dumb") is "I can afford that kind of sports car. So there's my superpower, lowering people's vision.
I'll add; your COMPLETE documentation of each step is something that you won't see on other forums.
I try, and some of the others on here as well. Something special about this site.
I'm trying to do similar with my work on our camper van upgrades on a Class B forum, but so few folks post photos, so you miss a lot.
The 1000 words - so-to-speak.
thankfully today we discovered that the transmission that's going to be glitter soon is a Super t-10 ... which will get replaced with a TKX... which will then pretzel the driveshaft and make more glitter out of the weak Corvette rear end....
but it sure is pretty before it goes full Bam Bam to the rest of the drivetrain
it's in for real
wow, it's been a day since I've updated this.... motor is in, we're going full knuckle-drag on it with a carb
and sidepipes.
everyone that I've been a part of their C3 Corvette build has sidepipes.... and you all say I don't make the world a better place!
here we see Paul in his natural habitat
ah the joy of sidepipes... this side is lower
then this side (picture representative, the picture I didn't take has the pipe solid against the body).
So now Paul gets to do the fun job of putting washers between the passenger side motor mount and the engine... fun fun
I'm curious how they fit in the engine bay. Tight to the engine, spaced mid width, wide mounts?
As part of your conversions to Sidepipes, which supplier do you like best?
we had to do some massaging on the driver's side to get them to fit. Mostly it's problem is a BBC in a car with a/c. The rearmost bolt on the passenger side is problematic.
My experience with headers. I have OBX on PF2, these are Doug's headers (owned by Holley). I also have put Hooker headers on a SBC (PF1). Quality, I like these. I also like they don't come with inserts (so you can fit based upon desired sound). I like the OBX because they weren't as expensive and are 304 stainless.
But the massaging for the Borgeson box conversion and to get them to clear is a challenge. I also don't get why I needed to put shims on the passenger side motor mount for both systems to get the sidepipes to fit (passenger side is low in the 'out of the box' configuration).
finally done with exhaust
had to cut the motor mounts, then moved down about 1/8" and rearward about 1/4"
but it now fits.... what a pain
starter is in, clutch is connected....
are those the specialty head fasteners? will the adjustment to the motor mount make it easier to access those for tightening?
I use ARP exclusively anymore. To me, it's cheap insurance - might add $400 to the cost of the motor but I'll never have a fastener failure... and I have had fastener failures with stock or things charitably I'll call "other"
we had Paul in the background in my Anthony picture... this is what he was doing
we are so close... I so want to just finish it but that wouldn't make more hotrodders....
