Plastic Fantastic 2
other then put the dash back in (4 screws) I have nothing really to do to be ready to run. I can even leave the rear in it... I won't because it's so simple to change - but that was kind of the deciding factor. If I can, why not?
Going into cold storage, so need to finish up some things
yeah, my favorite, wiring
better
it all works right... winning
so this is going to my new shop in Idaho - so it goes with all its parts. the list of to do: put the 3.42 diff in, swap valve springs, finish the light change, figure out the diffuser for high speed in October.... what I do I need to do before spring autox? none of it - so it gets to sit while I get more pressing things done related to the move
but for now, it sits on a charger while I get more stuff moved
I know I've been MIA for a minute. We're moving to Sandpoint Idaho. My fantastic shop... selling... but my new fantastic shop will probably break ground this summer. I hope to run Optima at Thunderhill in October... we will see
my 'new' shop... a garage condo. It will be where I do lift work and 4x4 work. My plan is work on the Buick (sorry, not the 50 yet) in my hobby time. Blazer is nearing completion but I haven't yet started on the camper for it. That's coming soon too... along with building a 60x60x25 2 story shop and a 3200 square foot house... it'll be cool when it's done and I'm really where I've always wanted to be.
Moving, building a shop, building a house, building a couple of vehicles,.... You know how to keep yourself busy!
back to this, first an oil change
I bought this filter last year at SEMA, finally getting around to doing the oil change to do it
next up, change the rear diff back to the original... I literally lost 10 mph off my top speed with the higher ratio (3.42 stock v. 3.91 currently)
You’ve probably seen these, I grabbed a photo because it looked homemade, and it had a simple design. But, looks like it may be a professionally manufactured one. IMG_4129.jpeg
On another note, the admin should move the Projects back to the top of the page in my opinion.
You’ve probably seen these, I grabbed a photo because it looked homemade, and it had a simple design. But, looks like it may be a professionally manufactured one. View attachment 57455
you'd fall over at what those sell for.... think "more than 40k before options"
Now that I've driven the car enough to get it fully warm - my report on the filter is it is excellent. Before my oil pressure would get down to 12 psi when fully hot, now, 33 lbs.
Rule of Thumb - 10#psi per 1000 RPM?
Only problem with that "rule" is there is no heat/viscosity factor included.
May have to pick one up for the other vehicles. Thanks for the report.
with the solid roller cam, single weights are required - I'm running 30w valvoline racing but could move up to 40w if I really needed more
Holy cow I fall a asleep for a couple of months and you are moving again ....i still want to see the lead sled!!!!!
hope all is going well, bob
