If it runs fine, run it till it croaks. Why not have some fun before it dies?
Spot anything like that on previous O changes??
:bonkers:
that looks like it could be the wear from the top of valve pushrods to me....did you use new pushrods?
Hard to tell from your pics, but if it looks and feels like fuzz or like paste then that is normal, not real shavings. You will get this on the magnet forever.
I used new pushrods but used rockers... hmmmm.... this one is relatively easy to check... easier than pulling the oil pan
Yes, it and looks and feels like fuzz .. almost like dried anti seize
So it looks like wet 2000 grit sandpaper??? and no metallic pieces you can see that are any larger??
rings wearing into the walls???
:bonkers:h:
Did you clean and blow out your new pushrods , I've seen some nasty stuff come out of them ?
Hmmm... not heard of "fuzz burn off" before. Is that pretty new technology? I've been working on old crap for years...Yes but, most turbines or jets and associated gear boxes have "Fuzz burn off" capability in the chip detection systems... Kinda wish we had that with our engines!!
It's funny Tim, the P&W TF30 (F111 engine) didn't have mag plugs but we used to do SOAP samples every 10? 20? hours.Every gas turbine/jet engine oil system I've ever seen has chip detectors (magnetinc plugs).
We have a saying in the big airplane world. If you pull it out and it looks like a Christmas tree or the chips have serial numbers it's time to pull the engine. Anything else is OK.
If the oil filter(s) plug up you get a warning light or a message. Helicopters have a light on the transmission that comes on when the detector sees chips. Helicopter world that classifies as "OH SH**"
No, the burn off technoloby isn't that new, H60's have it in their gear boxes. The chip detectors are shaped kind of like spark plugs, and if a chip bridges the gap, a small electrical charge burns it off. If it doesn't burn off, it sets the chip light. If I remember correctly, the GE T700's have the same chip system, but I might be wrong, it's been a while! Like Tim said, a chip light in a helo is really an "OH SH**!!" light! LOL
If I were getting that much material on the drain plug of my engine, I'd still consider a oil analysis. That way you'd know what the material was in the oil and that would give you a clue as to where it came from.
Gene,
Actually I think you're making my point. Because we don't know what's in the gunk, it might make good sense and a good use of $25 to have an oil analysis done, so you know what material that is. At least that way, you might have a clue where to look next....
