saudivette
Clueless In Sandland
Thanks mate.  Now that the bumper's done, I need to start hacking into my front guards and get the egg crate louvers grafted in there :thumbs:
The ones by the tag pocket are (going to be) backup lamps. The tail lights are from http://www.superbrightleds.com/truck_lights.htm.All 4 holes? Or are you asking which ones we like best?
Or are those by the tag pocket back up lamps????
I like those tail lamps.
No, I took a mould off the piece you sent me Gene - scroll back and read through this thread again mate, got some pics there.NOT BAD for a guy out in BFE....with nothing around but a computer....
is that the original piece I sent?? or is it a casting...somehow off it???
U do such NICE work,....I got this mess on my hands...
:devil::clobbered:
Anyway, I've had a change of heart - someone kindly pointed out that I don't need exhaust cutouts with side pipes!
:devil::clobbered:
Oh, what's BFE?
...I suggested the epoxy primer because your '72 grilles are FRP while your body is SMC. If the fillers you have available to you are not compatible with both...
the primer would enable you to get around this issue.
YES.....body filler can be applied directly to the glass as long as it is compatible with that type of glass.
Hand laid mat over gelcoat, probably polyester resin. Not even a chopper gun.
Nothing at all wrong with it. Just block the gelcoat staight and prime.
Gelcoat looks very shiney, not prepped with rough enough paper.
Epoxy primer is very good stuff, PPG DP epoxy is one of the best but a little expensive...
I think Marck meant epoxy resin instead of polyester, standard Bondo type resin will not stick to SMC.
