Plastic Fantastic 2
School of hard knocks, I’ve had more than my share. Hopefully you have it this time. I saw your post in the road race thread questioning dogs at the track, might want to start with the event sponsor, then the track, then state and local laws. But, I probably don’t need to say that to a lawyer. I was surprised that this state has a leash law, which suits me fine.
I called the track, they're fine with restrained dogs.
but in other news, we find out today whether or not he has lung cancer...
Valve adjusting.editededited
Hot lash is .016, since it was stone cold, I set it to .009
turns out that was really close.edited Warmed the car up and had to adjust a few valves but overall, about 50% of them didn't need adjustment. That said, I did reset them so that I'd get a good 'set' with the allen screw.edited I drove it, it sounds great, I'll drive it again tomorrow (more then a mile) then check the set.edited If I don't have to adjust, I'll leave it for 100 miles then check it again.edited my goal is 500 road miles before Optima....
in other news, I should probably change the exhaust oil seals on the passenger side... I think one is leaking
I hate exhaust leaks - and I swear by these
I get occasional passenger side smoke - thought maybe I had an exhaust valve seal going... but no oil in any of the ports or manifold...
top is left side, bottom right side
no oil on that either... but you can see how the driver's side is having trouble sealing - I've already replaced that one once and it's already gone
tomorrow's fight.... markers and signals.... when the lights are on, signals don't work but unplug the front and the rears do work
have you done as much reengineering of the body grounds and ground points as you have everything else? i found it was almost easier to run new ground circuits to lights then to rely on the old wiring system and if there are any LED lights in there you almost need a direct ground to the battery. on my 37 ford i had a clean body ground connection 3" from the grounding strap connection from the battery and could not get the LED flasher to work. and i mean it was clean.....i had to run it directly to the battery. it was really strange. i find with the fiber glass cars the cars back feed through lights to find ground circuits and really screw every thing up
good luck
the lights are on a new circuit - the switch runs a relay
light fix and aiming.... first, this wasn't opening far enough
and these two bolts adjust it
eventually new arms, but 'done for now'
then aiming
time to search for a C5/C6 alignment spec for Autocross.... tomorrow is alignment time
those look great, my C5 headlights really suck i am not sure how those got so badly designed by the engineers
neck restraint purchased.... I think that was harder to do then buying a helmet....
let's list the choices:
- seat angle (not the angle of the seat but where your head is in relation to the seat... oh yeah, and the seat angle too)
- driver size
- car type - I hear that since Porsche drivers hit the wall tail first, they need a different device)
- race type
- seat type
- seat belt type
and then
- restraint height
- restraint helmet fastening system
- restraint fastening to body system
- HANS is both a brand AND a description
- material device is made from
- whether or not you have seat belt restraints (seriously?) yeah, there is a choice of how the seat belt is held to the device....
and finally
- Aquarius? okay maybe I made that up.... maybe.
- but even more fun? I get to do this again when I replace the seats with ones that actually keep you in the car.... I know, I'm the millionth person to complain about C3 seats, but I should get a prize for being the millionth
sorry not the motors , i meant the quality of the light coming out of the C5 headlights.
I chopped up the light rings to put the Oracle lights in. I haven't really run it at night, but they do get bright.... of course, I'm running 4 singles so when it goes from bright to super bright it's 3x more light..... someday I may actually put the inners on a switch so I have 'regular' brights...
I've been meaning to check the alignment - finally I got a moment today...
high-priced-alignment devices
I'm glad I did
just the left was toed in about 1/4"
I'll check camber and castor tomorrow.edited Front toe is fine
I have been fighting the front lights, this is, I give up
they really fit poorly, but at the moment... I couldn't care less
onto exhaust
lay out circles
let's try an air die
make a funnel
then forever fuss with it
ah delrin
press
eventually you say "can't see it, don't care"
​​​​​​​if this works, I'll make a delrin die so I simply press the shape into the material.editededited
Got some miles on the car today, things seem fine - maybe cooling is a bit warm - but even that is probably gauge more than anything else
checked the rockers for looseness, nada... yay
Looking good. Still on track to make Optima - Willow Springs? In case you don't have other plans, the most convenient hotel option is the Hampton Inn on the North end of Lancaster. About 20 miles from the track. There isn't much in Rosemont.
I am going. Staying at Homewood suites in Lancaster - I think it shares a parking lot with Hampton. I was planning on taking my pooch and I don't think Hampton was cool with it.
I'm hoping I can leave my car and trailer at the track to make the commute easier. Looking at the 'traditional' schedule, the track opens at noon on the 27th - I should be able to be there pretty close to noon to drop the car/trailer and track gear then get tech'd.... I'm leaving at 10 am on Wednesday from Seattle, it's 18 hours of driving from my house.
A close friend is from that area, he gave me the 411 on Rosemont
narrowing in on refining..... this case, front signals
now signals AND markers work (winning)
now onto the coolingedited
put baby powder on the seal and see what hits
not much
easy enough to fix
define the holes
some CAD templates
now to clamp it in a way that the bonding epoxy doesn't make opening the hood an aggrevation
Tomorrow I'll take the tape off, clean it up then paint the blocks.edited the number one way to get cooling is to force the air through the radiator at speed... at this time, it's fine if I'm not pushing it hard, but if I push it for any time it starts to get warm...edited
tomorrow also.... horn.... because it's one point
with this I'm ready.editededited
first, a final shot of the hood
then worked on the horn.edited I need to space the button out further, but at this point there several problems with the system and honestly... I have better things to do then get a horn point.edited If you don't hear the side pipes then god help you
very clever, what did you use for blocking more door seal tubing or something else?
I have rope seal, but it needs to be at least 3/8... I'll bring the 5/16 with me but hopefully this is enough....
load in 20 hours, leave in 36.... can not wait...
In other news, practiced my egress (must be 12s or less in full gear - was 9), waxed the car. got the vent block in place.... I have sheeting I can use (that they use to cover wrecked cars) but it's not supposed to be wet - so I'll leave it off for now....
do they time that in a safety session? it takes me that long to get into the MGA coupe.....damn that opening is small
coincidently it seems like that was also the amount of track time.... FiTech computer went, so I missed the 3 sessions today and drove to Riverside to get another computer. Got back at 6:30 and installed it... I'm not sure why they call it racing, it should be called challenges.
oh well, new friends and the brief glimpse I've gotten has been a lot of fun.
FiTech.
Great customer service, but I'm starting to have second thoughts
this sight is become way too common
​​​​​​​this is what it takes to replace the computer
pull the injectors, pull the front then pray your way to get the computer back in place.....
This problems were as follows. The computer went out on day one after one track 'session' (but not really a session).edited Maybe heat? I dunno.edited So I ran 6 hours round trip to get a replacement computer.... and it worked right up to the point it needed to run the fan.... In talking to another guy there, his experience with a new FiTech was the computer provided a positive signal (as opposed to a negative one with the old computer).edited Even with the fan disconnected, I couldn't get it to run right..... so there will be a solid 3 or 4 hours next week on the phone with them trying to resolve its issues (which I suspect will be yet another computer)....edited
and let's recount, that's 2 computers on my FJ40, 3 injectors.edited 3 (maybe 4) computers on this one and only under warranty because of the manufacturer defect on the throttle body. Some how the tune we had in the computer got lost, but even that wouldn't save us....edited
I honestly don't know what's next.edited I really don't want to change the entire fuel system but I can because I have the carb setup I originally was going to run... to be continued
oh and now the grills seem to have slowed the air down to cool the car.... that I have fixes for... .but just one more thing
funny thing about the challenges, only maybe 4 people knew what was going on.... I figure everyone has troubles, they don't need mine
two of the problems have one source. I didn't realize that the headlight motors could draw 30 amps. I have a 30 amp breaker on the headlight motors AND the fans. Fans are 13 amps each.... still no answer on the EFI... but I have a fun time ahead of me rewiring a bunch of stuff.
to recap.
1) put dog to sleep night before
2) got no sleep, so had to stop on the way
3) my wife's dog took off looking for him - didn't find out until I had crossed the border to California
4) dog found after substantial effort (though I suppose it's funny - but dog got 1/8 mile away, someone captured her, took her to the local vet... dogs don't get away with anything around here ;) ) but it was 8 pm before someone who might know someone mentioned the impoundment and the vet closed at 7. Thankfully the next morning (while still on my way) found out dog was fine.... Old dame dog decided she didn't want to eat because of the stress.... (did I mention they're both Search and Rescue trailing K9s, so a lot of time and money invested in them both?)
5) Everything worked fine when I took the car through tech
6) but there was the start of the cascade of problems.... in tech they checked the lights, which caused the fuse to blow which powered the lights and the electric fans
7) car got warm-ish on the lap.... that probably overheated the computer.... which it shouldn't, but pictures tonight tell another story
8) computer went, took 7 hours to resolve and missed 3 events
9) car ran fine that night but didn't warm up
10) tuned IAC, went to the autocross to walk it, car was overheating.... no fans.
11) spent a lot of time wishing I had a bunch of stuff here in the shop - the guy with the silver C4 was a hero, he did have all sorts of parts.
12) hot wired the fans..... alternator took a dump
I probably could have fixed that but by then I was done.
However
on the plus side
1) I made a number of new friends
2) I got to go around Big Willow at 70% in my C3
3) My friends here dropped everything to help find my wife's dog
4) I got a lot of love about the car.... and 5
5) I'll fix it all and learn while doing it.
Sure, I wish it'd worked perfect, but I wasn't the first to go down or leave. And my goodness is my car fun to drive at even 70%.
so the lights didn't go up, but what's worse is only one motor was connected to the mechanism.... I saw this there, but given everything else... did nothing about it
40 amp relay, 12.8 (25.6 total) amp draw.... not good (this is the fans)
and a hot mess
what tripped me to the problem was the fuse kept tripping and not opening the light. I replaced the fuse and it was the amps being drawn, not just a faulty circuit breaker.edited
with that said, the motors could be drawing too much when hot.... this, I will test once it's back together.
entire EFI is going back to FiTech. Once I get it sent, I'll have to ask them their plans... part of me wants them to replace it with a port-injection setup... the other part of me thinks that would be throwing away all I've learned for something new to learn.....
how fast it gets back is going to determine whether or not July in Utah is a pipe dream.... I will not run again unless I get at least one autocross day and one track day (HDPE or similar) without failure before I go..... reasonably that means that it all must happen before the 1st week of July.... truth is that it's not looking good.
and with that said. I had trouble with my FJ40 - but now, reliable as a rock.... of course, I've lost my handheld so maybe there's a problem but I don't see it....
As mentioned before, I need to send the new computer and the even newer computer along with the entire throttle body back to FiTech
together
now a brick, again
Good thing I saved the shipping container - I swear that should be getting close to a free flight with all the times it's gone back to the manufacturer
I wish there was an easy way to put the carb on it for now.... but in-tank pump has way too much pressure
Add a return line and a fuel regulator. What pressure is required? I'd have theh same problem when I (finally) get the Weber Carbs on top. The old school solution - return line and regulator. The Webers have to be down to 4 psi. Well under an in-tank pump.
Just a quick thought - but may involve a bit of effort - and get you running.
Best of luck - the carbs would "bypas" the EFI problems. Suppose you'd leave the injectors in place?
along those same lines......can you kill the electrics to the in line fuel pump run an external cube pump connected to the lines and still draw gas from the inline pump?
