greg75vette
The Traffic Baron
Figured I'd show off my dump. Trust me, the paint looks a lot better in photos. I wanted a project car to build to my specs. One of the primary goals was to ultimately drop an LSx/T56 into it. I didn't decide how I was going to do some serious power (N/A or turbo), but I knew I had something special to work with. I figured a mid C3 would be the best candidate since it had looks (I prefer the rubber bumper and flat back glass look), IRS, and some low hp and less collectible years. I bought Pandora in May '07 as a college graduation gift to myself. She was, what I considered the perfect platform: a low hp (165hp L48), low collectability ('75 coupe), Solid fiberglass, frame, had the mandatory third pedal and she ran pretty well. The mileage was a little high (107K), she was # matching, and the paint and bumper covers were shot: all not so great things. However, the timing and price were right and I liked the option set, so I went for it.
The summer I brought her home. I bought her near my college and on the day I bought her, I drover her about 400 miles from Rochester, NY to Lindenhurst, NY:
I had some issues over that summer but nothing major. The following spring I decided to start making progress towards my overall goal for the car, which is simply for it to perform well and add some new tech to an old, sweet looking car. A restomod, if you will.
The suspension system was first. I decided on the VBP performance plus system mostly because people seemed to have liked it and I like that it has some adjustability to it.
I started the day after a heavy rain. Man was it wet in the driveway. That whole summer of '08 was wet. A big deal for the garage challenged.
What I started with:
Of course I find this on the first day. Diff oil coming out of one of the spring mounting blind holes:
So that had to come out. Got to look over the shape of the diff. From what I saw, everything looked OK. Ironically, Gary (gtr1999) recommended me to check out some of his pages in the rebuild section on this site. Little did I know I would later join and come to realize how this is the end-all-be-all forum with my kind of people :kissass:
A good shot of the crack in my ass. Ass end that is:
So I sprung for a new HD cover and got to paint her all pretty. She will need a rebuild, but I felt she was solid until I built up some more power out of the LS1 I was planning down the road:
The suspension pretty much finished for the rear:
The front end went a lot faster. I actually did the rear first thinking it would be easier:rofl: Boy was I wrong!
Some carnage and the 'assistant':
I didn't document the front as well as the rear. I flew through the front end since I really didn't have any snags. I left the brakes alone because the stockers are pretty good. I will upgrade to Wilwood brakes once the wheel/tire combo get a refresher.
I set the car low and I was quite happy with the improvement in handling. I'm she would be even better with a proper wheel/tire combo.
Notice how the bumpers have gotten worse through the pictures
This spring I had to replace my radiator core support and weatherstripping. The weatherstripping was by far the hardest project yet. I fear doing that again. Turned out my radiator was shot and my end tanks were stressed cracked. So I bought a re-core Cu/brass radiator off a forum friend which checked out well and performed through the summer (when I got a chance to drive her, had power steering issues). Why didn't I wait until my LS1/T56 swap to replace it? Didn't know the swap was happening anytime soon. Due to my flywheel being damaged in a bad start (from my wipers, long story) I had a bare spot on the ring gear. But finally, what forced my hand to do the swap nearly 2 years ahead of schedule was the throw-out bearing beginning to go from a mild squeak to a mechanical clunk. Right then I decided that I would no longer put money into an engine/trans I didn't plan on keeping. Between the radiator, power steering pump breaking, and now basically a full clutch job, it was too much for what I wasn't going to run.
Now things became serious...
