Thanks.It's because they are 2x GOOD?
Nice rake - or are you on the brake?
Looks real sweet on the track.
Like thoseGrabbed a pair of these before prices (possibly) increase. Going to get back on the cars soon.
i'm running the mx5 (miata) electric motors on mine. Never have to worry about them popping up by themselves again, and gets rid of the vacuum hoses (only vac line left on my car is PCV). I did measure the weight at the time, from memory I think it was pretty much a wash between the motors/wiring and the vacuum actuators and hoses. I did end up making some double shear brackets for the motors, I eventually cracked the single shear brackets (sourced from the Corvette Forum). But my car does get a lot of use and hard use at that.Yesterday's track day went well. Nothing broke or got scratched up. A few conclusions I came to during the day:
1) I need to brake later. I'm still trying to get accustomed to how much quicker the car decelerates with the decreased weight.
2) The car is very neutral through the corners, with a touch of oversteer when I ask for it.
3) I'd like more front grip. I can't find many more ways to pull weight off the car, so I may have to look for other methods (stickier tires, steering geometry changes, etc). I'll be starting another thread regarding Ackerman geometries pluses and minuses. I can move the steering rack position pretty easily, but I don't have a sure way to decide which position is best for my situation.
4) And finally aerodynamics. I'm getting down the straights quicker than before, the car feels steady, and the brakes and engine are apparently cooling sufficiently in the process. A problem I ran into repeatedly was the headlights popping up at about 120. I don't have the vacuum system re-hooked up after I pulled out the vacuum tank, so I had to manually close the lights after each session. I don't know if the problem is purely aero pressure getting under the headlights (or maybe entering the headlight opening gap behind the front bumper), or if it's a combination of that and no vacuum in the actuators to help keep the headlights down. I welcome input or suggestions about this issue, as my plans at the moment are to reconnect the vacuum lines and perhaps install a small plastic vacuum canister to compensate for small vacuum leaks in the system.
At a minimum I need to do that.I have seen the pneumatic logic diagrams for the headlights before. It reminds me of an old player piano (only the piano is more understandable). Could you cap the headlight vacuum actuator to lock them in place?
Now that we are on the subject, here is an experiment I intend to conduct. I have already built diffuser tunnels between the frame and rocker panels/side skirts. Air is fed to them via the front fender splash panel behind the tire and barge boards along the frame. I built CF plugs for my headlights, which have a fair size cross-sectional area. I made the plugs removable so I could just let air flow into the fender well above the tire. Now I need to build a simple CF upper/rear inner panel inside the fender well just forward of the firewall to smoothly guide air down toward the side pod diffuser entrance. It will be interesting to see if there are any benefits with regard to reduced frontal cross-sectional area or any improvements in downforce as more air is directed into the side pod diffusers...or, it is a total disaster and creates lift instead of downforce.
I like the headlight bucket method. I've wanted to replace my flip up headlights with fixed rectangular ones for years. I pulled the whole setup out of a late 80s/early 90s Oldsmobile that used the smaller-than-usual rectangular headlights. I then wanted to cover them and the bucket in easily installed/removable body colored covers for the stock look, but haven't come up with a reliable method for the covers that I'm comfortable with yet.4) DUCT TAPE!!
Or, LeMans buckets might be shallower if using modern rectangular LEDs.Then, you could swap the fiberglass covers with lexan and transparent blue mylar.Would look "semi" stock." Maybe less weight too. The stock light buckets are pretty heavy - mechanism, etc.
2) I guess that touch of oversteer is from a throttle "Blip"- or drop?" "...when I ask for it."
I enjoyed "pointing the nose" of the little racer that way. It was a real hoot.
I recall that being referred to as "Technique" - not "Procedure" in flight school.I like the headlight bucket method. I've wanted to replace my flip up headlights with fixed rectangular ones for years. I pulled the whole setup out of a late 80s/early 90s Oldsmobile that used the smaller-than-usual rectangular headlights. I then wanted to cover them and the bucket in easily installed/removable body colored covers for the stock look, but haven't come up with a reliable method for the covers that I'm comfortable with yet.
Years ago I accidentally learned how useful drop-throttle oversteer can be. I was at Mid-Ohio driving a Skip Barber school Formula Ford, and I was coming around the Keyhole in a good clip, and nearing the corner exit I concluded that I'm going too fast and pointing right at the wall outside the corner. I panicked and quickly let off the throttle, ready to hit the brake pedal, when I suddenly remembered the instructor saying "Never lift off the throttle in a corner with these cars.". I immediately reversed course and got back on the throttle. In that half second of letting off and getting right back on the throttle, the rear of the car jumped a foot or two outward on the corner, and suddenly I was staring right down the back straight, instead of to the outside fence. After learning that "skill", I've used it a hundred times in autocrosses, a few times on public roads, and once in a while on track days. It is definitely a hoot.![]()
