SuperBuickGuy
I have fuel lines and starter wires running very close to the headers. The fuel lines are maybe 5/8 inch away from the headers and I have them wrapped with a heat jacket and another layer of DEI heat shield with ceramic backing. That leaves me with about a 1/4 clearance. I like what you did with the titanium shield. I am thinking my main problem will be radiant heat and the titanium might be a way to address that problem. Also my pipes merge at the starter and there is very little clearance between the starter wires and header tubes. I do have a blanket that wraps around the starter but it really does not offer any protection from radiant heat. Maybe a shield there would work?
I would think so, the air gap is important in preventing the transfer of heat. On alot of the newer cars with turbos tucked right up next to electrical components it looks (to me) like they focus more on a good heat shield and distance/airflow than excessive heat wrap on the harnesses.
I assume your fuel system is return style? That should help with heat soak of the line too.
I'm not an expert by any stretch, but the heat stuff you've used (the wrinkly DEI stuff) can be in direct contact and won't have any heat transfer nor does it break down with direct contact. It's pretty amazing stuff, I used to think there was no difference but DEI really stepped up the game and what they make now - I won't use anything else because I hate doing things twice.
