SuperBuickGuy
I tell people to hold their whines, never works... how do you do it? is this one of those things that when I grow up and become a professional that it will happen? :beer:
Progress is looking good. :thumbs:
I don't mean to add additional work or annoyance, but would you be able to get a weight on the stock wiper motor if you have a slow moment? Thanks.
69427-
I've weighted a 71 and 73 wiper motor- a little over 5lbs. Thank you.
I'm running a newer positive switched motor- Olds- Buick - Pontiac which is also used in the Corvette the exact same motor but costs twice as much!!!
It weighs in 20% less ....at 4lbs That's directionally desirable.
The BOP have a cover that doesn't incorporate a delay- really easy to control with it's two speed motor and no shunt. Please pardon my ignorance. What shunt item/function is that?
original part number is 22072788 then superseded with 88961292
Mounts in stock location with 2 out of three holes lining up
Can you tell me which BOP models/platforms this wiper motor was used in? I'm planning on pulling the distributor and intake this winter, so this would be a decent time to take advantage of the extra working space to swap out the motor.
Your help here is sincerely appreciated. :thumbs:
Excellent info, Richard! The A-class pump was delivered a few days ago... I know it has a delay turning on, but Im hoping there wont be a notable delay for pressure request after its already been on. A friend of mine (DblTrbl on the other vette forums) is an electronics wizard and Ive already mentioned to him about doing some mods to this thing if I find that it has any short comings.
looking good. I could have my car moving under its own power by new years, stopping, though, would be an issue![]()
I wish I could say my car was taken apart for only 4 years. I'm thinking more like 10. But there is light at the end of the tunnel. I think I will be able to put the body on the frame next spring.
Looking good, Chris. :thumbs:
Wow, very nice!!!
I can see all 4 pictures. You should host them here. Then you are not relying on (the very unreliable) Photobucket.
Wow - Where'd ya get those fancy "Ghost" rims?
I'm now looking at the Toyo R888R 335/30/18's for the 'vette too. Been real happy with the r888 on the sports racer. Maybe give up 3-4 seconds a lap (3.7mile course) -- but last 2 seasons.
What kind of clearance do you have for deep backspacing? It will probably take 8.5-8.75 inches to get near zero scrub radius. I suspect your front clip has that much clearance built in, but the inner fender panels may be a problem.
Pappy
did you try imgur.com for your pic hosting, it's free.
what flares did you get?
