It seems like forever since I have been able to work on the Darth Vader Vette. I got some time in Saturday and today. Unfortunately, I did not take many pictures and most was nothing new - basically some mechanical stuff.
I dropped the rebuilt 3:36 last Thursday and on Friday, swapped it out for the 3:73 a friend had. After cleaning and a nice coat of gloss black POR 15 (everywhere except the bottom side LOL) I also applied a coat of the POR15 on the crossmember.
Sunday morning I mated the 3:73 to the crossmember and raised it up into place. I'll grab a picture later. I still have to paint the bottom and I want to powder coat the snubber bracket before I bolt that on.
Here is a picture of the TKO600
This unit comes with the bell housing, a new flywheel and a new clutch assembly. All I will need to purchase would be a new pilot bearing.
I also got the radiator and radiator shroud out tonight. I pulled the spark plugs out and rotated the balancer to get the distributor rotor pointing straight toward the rear of the car. The intake will be coming off and a shiny gloss black powder coated intake will be going back on in its place.
I ordered some POR15 gloss black engine paint yesterday - never used their engine paint before so this should be interesting. Not sure if I should remove the blue engine paint first or just clean and paint. Any thoughts on this???
One of the problems I have to work around - I had a small one car garage and the C6 rear clip will have to come off, massaged and replaced a few times. I have come up with a plan to use box rail - like they use of barn doors and make a monorail mounted down the center of my garage ceiling. I will post pictures when I do this. My thought is to raise the clip a tad, pull it toward the garage door until it clear, then raise it and move the clip forward.
Unfortunately, the only store that has it close by is almost an hour down the road - well worth it but getting the time!!!
That's it for tonight! I will do better with PIX next post.
John
