I chopped it off the GM cable and installed it on the Lokar cable (which already was crimped)
I gotta finish the front suspension first... Brakes arrive this next weekend, uprights getting finished at the machine shop. Pushrod shocks and springs are in. The air box for my radiator has been done for a few years. Just not installed - too much in the way.You mentioned a vertical rad. I always wanted to investigate using a short thick radiator that leaned forward, with electric fans ducted out the hood. I think I've seen photos somewhere.
lots of years ago, at the Corvette Swap meet (near Seattle), the 'show' portion had a really track prepped C3 with a vertical radiator. He used a shorter radiator - cannot remember what he said he used (RX7?).... I dunno if I'm going to go that far because I already have cooling issues, my last thought was a LS7 Z06 radiator would be sufficient. It wasn't.You mentioned a vertical rad. I always wanted to investigate using a short thick radiator that leaned forward, with electric fans ducted out the hood. I think I’ve seen photos somewhere.
so far so good...sorry to hear about your health scare i hope it resolves its self favorably
the camera is a Ricoh WG-80.... I'm not in love with it but it does have its moments.Nice Update. Good format.
What was the camera? Looks better than a phone (more stable and landscape format.)
Thanks for the full tour - makes me even more jelous of the space.
But, if I had it, it would be chocker as well.
The FJ40. Last night I was wiring in a double battery set up. I had the last piece - a negative terminal top post to stud converter sitting right in front of me. Spent an hour, never found it. Will go buy another today.... the worst part of the shop, in the last shop I knew where everything was (mostly because I'd put it there)... this one I'm hoping this summer I can drag all the cars out then start organizing... probably won't, but it is in my thoughts.Really nice shop and so well organized. Considering how many projects you have going on, that's remarkable. I spend as much time looking for stuff than I do working on stuff (with one project).
