and more knocked off the list..
the list
for those who forgot what the dash looked like removed...
squeeky clutch ... hmmmm
I didn't think it was possible... but here's the problem... they put the bell arm in backwards.edited But I don't think it was the PO, or at least not his fault... it's made backwards
first clue was the zert fitting... it wasn't installed - it's usually on the top, but it wasn't..
thing was, the ring that holds the cup (frame side) was machined into the wrong end. Add to that the hole for the zert was on the bottom.... turning it around solved all its issues.edited Now it can be lubed. I punted on the clip ring - I reduced weight.edited One clip ring
now the clutch works correctly, the difference is one arm is longer then the other - thus in the Corvette, where you don't have as much pedal travel as the truck, it won't work Worst, it sticks to the top of the hole in the firewall.
now it doesn't
In other news, and not on that list.. noise
and a way to test it
105db at 50 feet and 50 mph.... it idles at 100 db..... hmmm
