these cams are designed so that you don't need a bronze gear... that said, I haven't looked to see if the billet cam requires a soft gear.
in other news, the new crank is bent so badly that it cannot be straightened....
I’m no help on the clutch question, but if I was looking in the future I’d look here since the are pretty competitive in vintage racing.
http://www.duntovmotors.com/vintage-racing-parts-engine_driveline.php
The clutch they are selling isn’t cheap but I always say “why stop now?”![]()
Your question caused me to go back and look at my MasterLube Accumulator instructions. Hmm, I found no clarity there or the website - just a quick scan though. Speedway suggests the air charged piston; "...automatically forces up to 3 quarts of reserve oil to the main galleries." So it sound like it adds 3 quarts to total capacity.
There is a lot of reference to the "benefits of pre-lubrication." They cite the reduction of wear from reduced friction as a result of dry starting. I see the Accusump is at about $320 price point on eBay (as low as about $200). Price jumps with enhancements like automatic pressure solenoids etc. to $600.
They are pretty simple, use a pressure bladder inside the container and when the valve opens - forces the oil in the cylinder into the circuit. When the engine is running the oil returns to the cylinder and reserved. In a manual setup - you have one more thing to remember on shutdown. Checklist anyone?
I am moving to a Dry Sump setup, and redvetracr said he had used a primer on his setup. So, I bought a Peterson Remote Filter Mount/Primer. The primer is driven with a cordless drill and should bring the oil pressure up in a few minutes (also useful for oil changes too).There is nothing to do on shutdown so one less checklist item -- but there is the "priming" mentioned earlier. That could be effected with a switch (Red Guarded?) and a 12v motor to drive the priming boss. Added benefit (or challenge) - the oil filter moves to a remote access position.
The price point is pretty much a "push." Maybe comes down to the additional capacity as the deciding factor - which seems to be available.
Best of luck on the deciding! Sorry if I muddied the waters...
Clutch thoughts: For street clutches, I have had good luck with McCloud. Their twin-disk RST should handle 700+ hp and still be streetable. For more hp than that (850), I am using a Tilton 7.25 inch, triple disk carbon-carbon unit - not streetable. Quartermaster makes the triple disk clutch that a lot of the guys competing in the Optima challenge use. I also used an Exidy clutch in my track Focus - worked good, but a lot less horsepower. There is a photo of my Tilton in my 56 Vette build thread (the forum would not let me re-post it here).
Below is a description of the McCloud dual disk clutch:
"GM 1-1/8 x26 with Small Block Chevy and Big Block Chevy flywheel pattern
Fits 11" Pattern Flywheel Only
Intended for the high horsepower street fan, the McLeod RST twin disc clutch kit is an economically priced twin disc clutch kit. Able to handle 800hp, this clutch can handle almost any horse-power you can throw at it and still remain street able. Organic lined clutch discs will provide smooth engagement with a soft pedal effort to make this clutch kit ideal for the street performance enthusiast. This clutch kit is designed to be a high horsepower street clutch kit and is not designed to be used in a competition environment. Kit Includes: Pressure Plate, two organic friction discs, floater plate, adapter ring and pilot tool."
doesn't the tire grip or lack there of make it easier on the transmission? how do you figure what HP you lose because of loss of traction?
nice , nothing prettier then shiny new parts
as I said before I would still be crying.
.at the end of a year playing Golf what do you have to show for it?
