Plastic Fantastic 2
you are kicking some major ass there and I think your panel shear is big enough! I am glad you are thinking about the Buick....I want to see that build for sure.
with a name like SuperBuickGuy, you'll understand when I say "which Buick?" I think you're talking about Sledanet, but I'm actually working on Buinicorn (50 Sedanet and 64 wagon)
what I'm working on with the wagon
so the epoxy is dry but very green...edited
once it does dry, it looks like there is enough to fix the edges
same with trailing edge
well it never occurred to me there was more buicks…..purely a lack of my imagination are you merging the two 50 and 64 vehicles into one?
two different cars
time to start marking and fixing - on the other side, this is flat
the passenger side
mud slathered
and onto my other project while that dries
[]but I'm actually working on Buinicorn (50 Sedanet and 64 wagon.
Interesting, must look unique. Someone did a 50’s ford pickup with willy’s front fenders that looked good.
I have a 50 Buick Sedanet that got stopped by the motor ending up in purgatory. It's a 'typical' fat fender build except I've built a 430 ci Buick motor with aluminum heads and twin turbos.
The 64 Buick wagon will eventually get a twin turbo 3.8 liter Buick motor that will also run nitrous to intercool it. At the moment it has a 6.0 LS motor. This is the Buick I'm working on while doing the body work on the Corvette.
The Sedanet is my retirement project... it'll be chopped, pancaked, frenched.... as I'm 53, it will be awhile before it's even really started again. The motor machine work is done, and I have a transmission for it that has been rebuilt/upgraded... that said, I have everything left. I intend for this car to be my best - thus I practice on what I am currently building.
What are you using for your "mud?" Looks like a DIY-mix with resin.
I've had good luck using colodial silica and micro balloons, and surprisingly - TALC (listed in order of "sanding" difficulty). The talc is nice as its very easy to sand, and has a nice odor.
I'm always looking for alternatives.
West epoxy systems with 404 filler
Good One! :thumbs:
maybe it's dust-induced-delusion, but I think that once I coat the jams tonight; I'll be done with epoxy then I can move to sanding jambs and then high build primer....
then again, I've fooled myself before and I suspect it will happen again.... wish I'd stop doing that :hunter:
more forever work
epoxy the jams
before
after 2 hours of cleanup, grinding, sandingedited
and epoxy
time to glue in the shelf
whoever owns this car later.... I told you to read the blog.... you didn't, and yes, it's glued because I hate rattles and I don't care that you're now trying to get the frame off
glued in place, and it will even be glued more before it's done.... did I ever mention I really want to have one of my cars on one of those reality shows where they bought it and now are complaining about that cold breeze blowing up their skirt and chilling what used to be their manly bits?
if I didn't, now you know....edited
more barely seen work
trimmed some edges
then filled in some corners
keep in mind that all of this gets ceramic sound deadening then carpet... I just want to plug the holesedited
wonder how long until I see this at a Chinese booth at SEMA... ah well, here it goes... I'm building a grill that opens - this is just in front of the air cleaner, so allowing air to escape, but more importantly get cold air directly into the motor will be beneficial
​​​​​​​Kind of depending on the response, I may make a few extras
and the underside - I didn't paint it black because I've worked under a car in the pits - having a silver floor makes seeing problems SO much easier... the inner fenders will get rubberized coating but the floor... silver
Wow. You’ve really gone kind of exponential in the magnitude of the project and expanding your skill set.
You can’t blame me for thinking the two Buicks were going to become one car. Yes, I misread, but actually thought you might actually tackle that.
Seeing those door jams makes me cringe, they are such a pain. Good job.
Dittos on the copy cats, my engine stand frame jig was for sale a while ago, somewhat nicer though.
thank you for the kind words, they help a lot
sometimes I wonder how much faster it would have been done had I not gone to SEMA. That said, SEMA is the highlight of my year and it is a far better car than before
not much to report, did a wiring project and fell a tree so fun stuff didn't really happen.editededited
That said
glued rails into the car
once this dries, do some epoxy make-it-look-good then onto the final acts of paint
promised picture
it wasn't drying fast, so I added heat.edited The coating is water-based, so making it flow is pretty easy (just add water)... of course, the temps are low then it dries slower....edited
Did primer...
got bugs doing the breast stroke
got set up, covered everything up
and got to it
same view, with primer
new views, with primer
flares turned out okay
I'm still not thrilled with the left front, but I think, by these pictures, I see what I need to do so it shouldn't be too bad to get it in line
of course, cleanup took longer then the actual painting
lots of little things, but overall, it took a big leap to done
so I took pictures earlier.... for whatever reason they didn't get on the memory card... so these are round 2.edited The first set had Buick in my Buick wagon snoozing.
I dunno, maybe either use it as a template or cut it down so it clears the air cleaner
it turned out a lot better then I expected
hard to see but the front flare is now nearly close enough
other side for comparison
tomorrow I'll do a walk around with a to-do list.... it's not bad
so I may outsource the actual coloring of this car - which means I need to get the major done now....edited
it's good enough for white.... not black, yet
this gives a good perspective of the front fenders
much sanding later
time to cut a hole
no going back now
and voila
Very NICE! The "grill" seems like a niche product for sure.
Could be driven with temperature activated solenoid - a bit more complicated construction - but useful.
I agree, I made a conscious decision to use this for now then build exactly what you're suggesting once it's on the road. There's several things on that list, such as:
Corbeau seats (though these may happen soon)
race-prep transmission with scattershield
go-fast a-arms
splitter
wing spoiler
custom center console
I don't want to wait another year to get this on the road so some accommodations are being made now to things that I can change pretty easily later.
Chris - I hear that! I'm in final phases on the SR to get a few final races then prep to sell. Then to get back on the 'vette. You've made a lot of progress that I need to do as well. And many of the same items on my punch list.
go-fast a-arms
splitter
wing spoiler
Kirkey seats might be more appropriate :)
Kirkey - with bead set installed!
But with all that great welding skill - maybe a custom made Aluminium (downunder spelling intentional) Bucket. I have a set of plans I got from Rorty:
They used to be posted free and now I see he is asking $10AUS ($6-7 USD) but you get manual and dxf's if you want to cut your own - or he'll sell you a cut set and you fold and weld. ($190AUS or about $120US -+ shipping from OZ.)
If you do your own layout - another niche market? I'd have to look to see what gauge he is using - but I'd bet you'd figure it out.
it'd be cool to build....
bent to hood contour
I seriously hope this is the last time to fit the doors before paint
sexy
finally the front flare is showing the right shape
Lots of pictures, but the point is it's pretty much all sanding today
all of these are low spots
and chips
and fill
so twice this amount of liquid and you get peanut butter
you have no idea how tempted I am to paint this white
so while the filler is drying... onto the Buick
so I used the wrong squirt nozzle for the epoxy, so I got to remove what wasn't drying and replace it
oops
then tonight I got to use all-of-my-epoxy-knowledge and help another person.... I know what the blind leading the blind looks like.... his turned out better then mine - but I think he had more YouTube videos under his belt ;)edited
and for the record, he would have made the same mistake I did.edited West Systems comes with 3 dispense pumps.edited 2 are for the hardener, one is for resin.... but one of the hardener tops is the same size as the resin (they all come with varying lengths of pickup tubes).... tonight as I was mixing the new batch I noticed printing which illuminated my error.edited It's a really easy error to make so don't be me :)
especially here on VetteMod. I know it seems like I know what I'm doing - and many times I do - but if you follow what I do, trust but verify ... I'm not ashamed of learning, but following what I do comes with an inherent risk that I may not.... when it comes to fiberglass or epoxy work.... please keep in mind that this is for your entertainment, not instruction.
