- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Trying to figure out what I need here. I just noticed that the oil filter area is different on this block. My old block has that aluminum adapter piece that bolts in the round machined area of the block, but it looks like this block doesn't have the inset area or the old pressure relief.
Looks like the filter gasket butts up against the round area, but there's no room for the old type adapter. Is a Gen V or VI block similar to this block? Looks like I need a wierd pipe nipple with a large OD (.910) that threads into the block, and a smaller OD (.765) that the filter threads onto, assuming I can still use my old PF-25 filters. (The filter OD looks compatible.)
So, any suggestions? Anybody have a late big block that can tell me what sort of pipe nipple arrangement goes in here?
thanks,
Mike
Edit: I also need to figure out what fitting I need to block off that hole that short circuits the filter. If you look at the three holes from top 12 o'clock on down, there is a passageway drilled from the top fitting downward. This is just one more issue that's different from the old block, and it's slowing me down.
thanks,
Mike
