EXTERNAL AERODYNAMICS
phantomjock
City & State/Province
Retired Again!
We’ve a lot of good discussions that have wound up in the “Internal Aerodynamics” thread. The topic I’m bringing is focused on EXTERNAL MODIFICATIONS, so thought I’d start as such.
Rather than ask to realign any of those items, I have done a quick catalog of EXTERNAL AERODYNAMICS.
Other Corvette External Aero Threads:
FRONT END LIFT:
FRONT SPOILER VS AIR DAM:
REAR SPOILERS:
FRONT SPOILER:
https://www.vettemod.com/search/551033/?q=front+spoiler&o=relevance
FENDER LOUVERS:
https://www.vettemod.com/search/551034/?q=fender+louvers&o=relevance
WING:
https://www.vettemod.com/search/551030/?q=WING&o=relevance
DIFFUSER:
https://www.vettemod.com/search/551031/?q=Diffuser&o=relevance
SIDE SKIRTS:
https://www.vettemod.com/search/551036/?q=side+skirts&o=relevance
First, I wanted to address the aerodynamic challenges of an early model C-3 Corvette.
Specifically the “flying Butress” design rear deck.
I had previously “labeled” this image, and I wanted to see if I could visit the same issues in a CF model. I have teaching myself CFD and it is a “natural” addition to my other aero background(s).
A simple model used for many CFD studies is the Ahmed. It is a relatively simple shape that students us to learn CFD and then run a model in the wind tunnel to verify and compare the results.
This model represents a C-3 Variant of an Ahmed model:
I loaded up the model int the software and ran some profiles. I used a range of speeds, and 40 meters per second is a pretty good one as it is pretty close to 90 mph. I ran the models at full scale to avoid any conversions and Reynolds Number issues.
This is the output of one of the runs:
You’ll note the similar areas of turbulence on the rear deck. Because this “slice” does not include the vehicle sides, the turbulence around the wheel mirror and outside of the rear deck is not shown.
The Baldwin/Motion modifications are often suggested as an aerodynamic choice to improve the airflow. This custom mod is an interpretation of that approach:
My block model CFD run to compare is here:
Easy to see the turbulence on the rear deck in this run has been eliminated.
Next, I wanted to see what the run would look like with a wing on the rear:
I won’t offer any conclusions regarding this run. My version of the software is limited to 1000 iterations, and it is difficult for the program to reach convergence with that limit. But it does give some general ideas. The software also restricts the number of streamlines and other bits of useful information – but it is free and a great learning tool.
One of our own forum members did a rear deck mod similar but not as drastic as a full Baldwin mod.
Here is denpos’:
“Back in the day” Ecklers offered parts to effect such a mod. One I think would be interesting and offer a CAD/CFD challenge is the rear Louvers seen on this catalog page:
Meanwhile, I have prepared a set of 18-20 variations on a C-3 early model. These include the Baldwin, a diffuser, splitter, air dam, etc. A smooth sample of one of the Motion versions is here:
For these I’ve removed all the trim, mirrors, bumpers, door handles, and blocked off the front radiator inlets. The software is much easier to run with fewer such complications. Perhaps less realistic – but close enough to compare these various mods.
I’m putting my pencils (and mouse) down on this project for a bit. I’m preparing the headers for ceramic coating. Then I need to get the aluminum cut for the belly pan, followed by some interior work. Wiring, fuel and brake lines, etc., etc. I just got the parts in to resolve a bump steer with the steering. These activities will be all in Elvira’s thread.
Jim, thanks for pulling these together for review. I'd forgotten about many of them.
The yellow '73 (IIRC) with the wool tufts is a test that I'm trying to do to my car this summer, and focusing on the side skirt area. Years ago I removed the stock under-door panels (I can't remember the correct name for them) and replaced them with lower/deeper (painted) Lexan pieces, hopefully accomplishing two objectives: covering up that unsightly transmission crossmember hanging under the car, and secondly, hopefully making it more difficult for air running along the sides of the car to swirl and enter under the car. But currently I have no data or evidence that perhaps all I've accomplished is the opposite, retaining undercar air that would have otherwise tried to exit outward. The wool tufts would give me a quick answer, but I'm a one man operation with the car, so nobody to monitor or video the area. I do have some very sensitive differential pressure gauges, but I'm not sure about getting good differential readings with the moving air.
Just another experiment on my list of stuff to do.
Damnit!
rtj - you just gave me another assignment!
I recall there is a relationship to the height of a gurney flap and the chord length.
Hmmm - would you wanna bet the same (or close) could hold true for body length and (NASCAR-style) spoiler height?
Added to my many items I find interesting.
Cheers mate!
Reference the post in meme links...
img_4355-webp.57478
An item I've been interested in trying out, and had mentioned to Jim in passing quite a while back, is some sort of small cowl structure (preferably in clear Lexan) to cause some airflow stagnation at the base of the windshield. My goal would be to increase the air pressure at the windshield and base for a touch more central downforce on the car, and more drag during braking (the extra pressure at the cowl might possibly improve the airflow into the L88 hood and engine output to modestly offset the drag component at WOT in the straights). Whether any of this will be noticeable or measurable I don't know. I'm just out of better ideas to try to improve the car's performance while also keeping a mostly stock/sleeper looking vehicle.
Keeping the stock look makes it tough.
Maybe try raking the body a bit (lower the front and/or raise the rear).
The floor you put in under the engine compartment might like more rake.
How about a traditional looking chin spoiler that is really a modern splitter.
He put some thought into this. Not sure about the thick center, but the diffusers on the ends are known to work.
An item I've been interested in trying out ... is some sort of small cowl structure (preferably in clear Lexan) to cause some airflow stagnation at the base of the windshield.
Two very good goals here:
1. Increase the air pressure at the windshield; " the extra pressure at the cowl might possibly improve the airflow into the L88 hood and engine output.."
2. More central downforce on the car, improved braking {more drag during braking)
Goal 1. More Air Pressure at Windshield (BASE):
"Whether any of this will be noticeable or measurable I don't know. "
I think so. A manometer could get the info for the cowl, and pressures in the engine bay. I do recall "back-in-the day" hoods being opened (slightly) on a run to boost air into carbs. Again, measurement would tell.
I like your thinking on some Lexan - clear. Just focusing on the base of the windshield - it would be interesting to see if a Gurney Flap could make a difference. Here again - A-B-A testing. For testing you could use double stick tape and a strip of aluminum angle. For simplicity I'd jut focus on the center of the hood. Focus on the first task - looking for air to get into the engine bay. I'll dig out the ration of height vs location. The difference between 0.75" and 1.0" might be noticeable. As well as location for and aft on the hood centerline. Further forward shorter Gurney Flap and taller the further aft you go. Good time to do some Tuft Testing. This would show flow - but not pressures. With either the manometer or tufts - Be Careful driving with a camera!
Goal 2. Central Downforce:
"I'm just out of better ideas to try to improve the car's performance while also keeping a mostly stock/sleeper looking vehicle."
The most simplistic, and unseen change to increase downforce is under the vehicle. A splitter with dffuser sections will create 2 - 4 times the downforce of a "plywood splitter." The splitter could be fabricate to have the silhouette of a Pace Car Splitter, and the added benefits of "sorta" canard ends, as suggested by rtj. A full belly pan sloping down from front to rear, lowest point where you want most DF (close to CG). Slow rise to the rear with maybe a "break" to 23 degree (max) at the rear tires to exit? Not optimum, but might get most of what you're looking for. The addition of some rake is always (almost) good. Again, shout-out to rtj.
Somewhere I have a sketch of the inverted airfoil on a C-3 belly pan. For now, consider this as an approximation:
full
full
You can visualize the slope from the front under engine ( the dotted lines) to the lowest point and rise again to the rear. A lot of effort, adds some weight. Interesting possibilities to consider. I too am nearing this possibility as I am dropping the bellypan and floor 2 inches. I am looking at how much slope I can get from the front , under the engine, steering, etc and then aft to the rear suspension. etc. If I can't, at least I'll try and make it flat, with rise in rear.
The "more drag during braking" could occur if/when the nose dives during braking. Again from just an aero perspective, the "shaped" belly pan would be seeing a slightly larger angle of attack and could introduce some more lift - or stall. In either case thee would be more drag - making a minor contribution to slowing the car.
A lot there. Hope you can find some useful nuggets.
    71.3 KB
I'll add a few points. First found my chart:
Then I had a bit of thinking and sketching:
So I think worthy of a quick tuft test, short angle double stick tape and see. May not get the extra pressure at the base of the wind screen - depending on engine bay pressure difference. The turbulence may be re-energized enough to go where you want. If/when I have a moment, I'll try a cfd. But given the restrictions on the free version, may not show much pressure increase.
Here is a sample that you can "fiddle with." It is one I ran a few months back. It shows a nice "trip" point [yellow to green] on the hood for a forward most position for a gurney. Then look at the area just aft of the rear deck spoiler. notice how much lower the pressures are there. Might happen at the windscreen base that way too? Testing required.
As a side note - you can see the general flow beneath is really "asking" for some sculpting. This was basically a flat bottomed diagram/model.
Thought I'd check in so you would know I was still around and working on aero. Teaser - how about a center bar for the grill of my 56 Corvette track car with an integrated, adjustable airfoil and ends of the bar that act as canards as they go up into 4" brake cooling ducts on either side of the radiator. Finished the front undertray with 4 diffuser tunnels and provisions for any splitter extension made for a Viper ACR to be bolted to the leading edge of the undertray. Working the side skirts and the outboard diffuser tunnels. More to follow.Grill Bar 2.jpgGrill Bar 1.jpgGrill Area.jpgSplitter Undertray 2.jpg
Pappy - as always - Very Nice Work. Do you have a good source for the CF you can share?
Looks as if the Viper piece runs just under the radiator and into the engine bay.
I like how the forward tunnels appear to tie into the inner fender wells. All that pressure will be heading for your louvers I bet.
Anything happening to the radiator? Asking about shrouding for entry flow? Or was that "standard"?
Thanks Jim. The undertray has a "step up" notch to allow the Viper splitter extensions to be flush with the undertray when installed. The undertray extends back to and flush with the bottom of the engine which is set well back, and there are barge boards that direct the airflow from the diffuser tunnels into the side pod diffusers between the frame rails and the side skirts. A front radiator diffuser duct is formed by the CF panels at the sides of the brake ducts and an upper curved panel. The center bar and wing act as an airflow "splitter" to direct air toward the upper portion of the diffuser/radiator. I get my carbon fiber from Fiberglast:
https://www.fibreglast.com/collecti...WIS22KvumUm_Jqx8qsvvDH4MtAk0uqWdvKU4G64yZk0vlSplitter 7.jpgUndertray 5.jpgUndertray 8.jpg
Pappy - Both your's and yer buddy's have some nice features.
The serrated endplates make for nice wake management.
That technique offers some interesting possibilities to add to quiver of "aeros."
I note the thickness of your splitter - what is the core? Foam, Honeycomb, ply?
Adding any rub (poly) pads underneath?
The CF splitter extension (from Doug Shelby) is honeycomb core. The black one with the red edge is a solid, harder composite plastic of some type - durable but much heavier. The stock Viper ACR splitter extensions are also the harder composite. The new one I am building is foam core with Kevlar on bottom and CF on top. I have three CF struts for splitter support from Professional Awesome - those have titanium pucks on the bottom of the splitter as rub blocks.
Nice work on the C1.
On another note…
I have been noticing this lately. All new pick ups, regardless of brand, seem to have a “duck bill” on the tailgate now.
Toyota, Chevy, I think they all have it.
Lots of interesting items being shown and discussed. I'm enjoying this thread.
While I'm trying to figure a robust enough design for the cowl area aero flow spoiler, I've added a couple more feet of undertray to the car (about four feet total back from the Pace Car spoiler) and looking at extending the front air dam down another couple inches. Due to the long nose on a C3, a splitter shelf has to be awful damn forward to not just trap air between it and the higher bumper area, so I don't currently think extending the Pace Car spoiler horizontal surface further forward is going to be a good ROI of time and material for this car. The lower height of the air dam should hopefully reduce the amount of air entering the bottom of the car, helping cornering traction, and particularly front tire grip during braking. I reduced the front suspension anti-dive percentage a few years ago when I read about compliance issues with high amounts of anti-dive. I'm comfortable with the current level of dive during braking, and I guess I'll see if anything now scrapes the pavement.
I'm now looking at directing whatever air I can from under the bellypan/engine out to some vents in the under-door mouldings. I'm still in the design phase, trying to come up with something that won't accidentally end up trapping air in the area as well.
I hate adding any weight to the car, so I'm going at all this pretty slowly at the moment.
"...splitter shelf has to be awful damn forward to not just trap air between it and the higher bumper area...
Fastening an airdam could be useful, but require some mods to the Pace Car Spoiler. Maybe 'glass in a lip to blind fasten to?
I could be way-off here - sold the Pace Car Spoiler over 15 years ago. so have no real-world data to work from. But I recall the lower lip was substantial(?).
airdam spoiler+ splitter.jpg With some thought could maybe be removable for DD?
This may be a little hard to explain, but here is what I would suggest. Add brackets to the frame behind the front fascia to support the splitter, Then attach the air dam (really a filler panel in this case) to the bottom of the spoiler but do not attach it to the splitter as a supporting member. Instead, add upward tabs to the top of the splitter behind the air dam to prevent the air dam from pushing back. This "support could be a simple piece of aluminum angle formed to the shape of the back of the air dam.. If you hit something with the splitter, or if it pulls down any with the aero downforce, it won't put stress on the air dam or spoiler. I did this with my C-1. The splitter support is fairly substantial since it supports both the splitter and the front of the undertray, but it only weighs 6#. In the first photo you can see the splitter/undertray support structure. It is bolted to the frame, and the undertray then bolts up into the structure using countersunk bolts. Then the air dam is added - it bolts to the body behind the bumperettes and to a couple of aluminum brackets inside the center cooling duct. Finally, a CF filler panel - much like you show above as an air dam - fills the gap between the air dam and the splitter. It bolts to the bottom of the air dam, but is not secured to the splitter/undertray. Hope this makes sense.
Pappy good fill. AND, good example on the C1. I'll use some of that on mine too.
That 6# structure - you doing your own TiG? I need to add that to my bag...
The Airdam on the C1 is exactly what I was trying to 'splain.
Came across an old pic that might show how to on a C-3:
The piece in the lowest segment could be "worked" and supported to be the gap filler.
View attachment 57541 With some thought could maybe be removable for DD?
That's pretty much the exact setup I've been running for several years. (y) Last week I added an additional one inch lower strip to it for track days. It comes off with six bolts for street use. Behind the airdam I have about four feet of Lexan bellypan to discourage air from just balling up in front of the radiator or up into the engine compartment. The sides of the Pace Car spoiler seem to do a decent job of causing a low pressure zone at the wheel faces, pulling air (and brake dust) out to the sides. I've got some air directors on the lower control arms to direct some of the undercar air up into the brake rotor centers for cooling. (I felt like this was kind of a hillbilly modification until a few years later I saw a similar factory setup on C6Z06 Corvettes. 😆 ) So far I've never had any issues with overheating the brakes.
GM put a deflector under the engine support on IROC Camaros that was much lower then is 'normal' - it rarely dragged and was pretty effective at helping keep the engine cool. Never considered it would help the brakes too but I'm sure it did
Mike, interesting comment about air balling up in front of the radiator.
I'm going from memory so I am probably mis-remembering this. The lower valance (front) of my 68 has a pretty big opening on each side of the bumperettes, which pushes air into the frontend (in front of the radiator). I think those two openings were closed off on later cars?
I'm not following what that was (under the engine support). Are you referring to something other than the air dam under the radiator support on some other cars?
My car has those same openings. I haven't had engine overheating issues, so I've been incrementally blocking off the air entrances to the radiator in an effort to reduce the amount that eventually finds its way under the car, increasing lift and drag. I have both front outer grilles blocked off, and those two underchin holes 50% blocked off. I keep considering completely blocking them off, but I haven't as that increases the surface area that any air pressure above the top surface of the Pace Car spoiler will push onto and increase lift a touch. I would like to block off the center grill some (or a lot), but I haven't come up with a good/strong way to fasten the blocking sheet/surface.
The frame area between the front grille and the engine is so aerodynamically dirty that I figured even someone as unqualified as me could still clean it up a touch. My hope/goal when I added a short bellypan from the spoiler to the oil pan was to prevent undercar air from leaking up into the front of the radiator (increasing lift and drag) and also from undercar air getting trapped between the engine and the radiator, slowing airflow through the radiator. And, any air that leaks from the front of the radiator or gets trapped between the radiator and the engine now has a horizontal surface that the blocked (modest) air pressure will push down on. I also have horizontal aluminum sheets between the header collectors and frame rails to reduce trapped underhood air from going under the car, and persuading it to exit the side louvers instead.
Just a step up from shadetree engineering. 😊
