Accusump install and oil filter question
Kicking around putting an Accusump under the hood over the winter. One question that's bothered me is what happens when the oil filter is pressurized in the opposite direction when prelubing the engine prior to start-up. Do the pump gears create enough restriction to prevent just back-flushing trash out of the filter and pushing it back into the pan? Or, will the reverse pressure swell the internal filtering media and possibly weaken/damage it?
Am I over-thinking things, or just over worrying?
Thanks for any constructive info.
Don't know/can't say if over thinking/worring too much. I did recall it should be pressureized @ normal running pressure, so had to take a look at my files. [My acculumulator is awaiting install too]:
Could plumb directly to the oil galley. That gets it where you want it, but the pump could still be there. Covers the bearings for sure, maybe not the top end? Could be a little more work and chance for a WIAT* though...
*"While-I'm-At-It"
http://www.accusump.com/accusump_tech.html
I was curious too. The PDF instructions show a check valve.
Fig 2.
http://www.accusump.com/accusump.pdf/instructions.pdf
Keep us updated on this upgrade. I'm interested to hear more.
The problem with a check valve is that there needs to be more external plumbing to put the valve in the Tee line. I just want to run the line from the Accusump to the threaded port above the oil filter boss. I need to do some additional research, and I'm curious if there's a PF-25 filter version with a checkvalve in it.
I have one installed and if you don't use any kind of one way valve, they oil flows backward.
To note is that the one way valve that Canton supplies is a serious restriction to oil flow. I ended up using a ford filter that prevents reverse flow. Works like a charm.
Oh and connect the accusump in between the filter and as close to the block as possible.
Might be a good time to add an external filter and oil cooler. I don't like the idea of back-flowing the filter either.
You know this additional oil adds weight - you'll have to diet.
This may not pass the constructive info test but my friend has a Rolls Merlin powered ride that uses a pre-oiler.
Happy New Year
Found a couple filters with anti-drainback valves (according to the Summit website). The Wix 51060 and the AC 19187301 appear to be some parts to try. Just for amusement I think I'll e-mail Wix and ask if higher reverse pressures (during pre-lubing) cause any durability issues with the valve, and typically what is the forward pressure drop across the valve.
Pays to ask first, doesn't it? I'm interested in hearing their answer. My guess is you've got a solution.
Yes pleas keep us informed. Will you add the cooler and remote or just the Accusump for pre-lube? Seems like good insurance - cooler temps (thermostat controlled), more capacity, and easier filter swaps. Small weight penalty for the added benefits I'd say.
Cheer - Jim
Cheer - Jim
The long term plan is to add an oil cooler too. The block has several (3?) tapped ports above the oil filter, so (hopefully) the plumbing ought to be pretty straight forward.
I went w/ a drysump-
I did it mainly because it was my only option the fit the engine. This is a street car...more grand touring style.
Cost-
$500-600 for hoses/fittings I used Earl's- made in the USA and they had fittings I could polish - plus they have 30º fittings which I needed for my application.
Dry Sump Tank- $300- I went w/ a Canton as I was able to fit it under the hood after removing the vacuum tank. And they are really nice looking
3 stage pump $550- I went w/ a Nutter Racing pump- Looks like a lot of pump for the money- and the guy has some good references on the pumps and the motors he builds.
Drive belt system- $350 Some used parts- some made and Peterson HTD gears
Misc-bracket/breather $200 A Moroso breather and a custom made bracket
Oil filter canister- A stock BMW piece -has an output for oil cooler and it has a anti-drain-back valve built into it. Made some AN fittings for it and it's done. I used a banjo fitting for the mechanical oil pressure gauge. I ditched the clock and running an oil temp gauge in place of it.
Oil pan- stock pan modified-a good buddy of mine welded it together-I used some P/U with strainers to keep pieces out of the pump.
SO - easily over a couple grand- and I watched what I was spending but didn't cheap out.
13964305355_9efe72319e_b.jpgDSCN4080 by Richard Hayes, on Flickr
Oil tank-
14848523595_d564e10a74_b.jpgDSCN4631 by Richard Hayes, on Flickr
Oil canister-mech gauge test run
oip pan P/u w/ heat shield
Belt drive
Oil filter /canister-
