bobs77vet
the body is on but not bolted on.
two of us about 2 hours, no lifting used the floor jacks the entire time, treated the M/C like a brake caliper, no real issues
lifting lowering the back i put two bolts in the bolt holes that were long enough that when the body came down it helped align it
treated MC like a brake caliper
removed all jacks under saw horses
slowly lowered went from front to back
last spot before we could use the smaller floor jack in the back
you can see the alignment tools sticking up to help get things lined up right
front extension install
and valance
and the first drive
and measuring up from the floor the front tires openings are exactly the same height and the rear tires openings are 1/16 off....not bad
celebratory first wets
and valance
and the first drive
