C3/4/5 frankenstein frame
vette427sbc
City & State/Province
Jersey Shore
Finally making enough progress to warrant starting a thread... Done messing with the stock stuff, so my plan so far is to take my '69 frame and update it with C4-based rear suspension and a C5/6 based front suspension. I went and purchased Performance Trends Suspension Analyzer so I will be attempting to design my own geometry for the front and rear using a bunch of educated guesses on COG and various other vehicle elements. I am going to make as many adjustable suspension points as I can to go along with my educated guesses made during the design process. Being that both of these suspensions have wheel speed sensors, Im also going to try and get a ABS/Traction control system from a C6Z (hoping to have similar weight, balance and tire sizes) and integrate that into my car.
For the rear I have a D44 out of a '96... 3.54 ratio and ~60k miles!
The front came out of an '01 (I think?) with 34k miles
Had a couple friends come over to help get the body off.
(click for time-lapse vid)
And as of tonight, the diff is hung via the batwing. Still need to make a pinion mount.
Going to place the trailing rods on the inside edge of the frame rail like yours... I will deal with the added track width of the later rear with different wheels.
I've been mulling over doing this as well to my next C3 - though, I'd solve the track-width problem with the flares I have on the shelf....
thanks for posting, keep up the posting.!
I'm interested to see how you go with this ,
I'm doing someting similar ,C4 rear and front suspension.
I have the rear of the diff lower to get 3 degrees pinion angle .
Bfit
Have you ever heard of the method of jacking the front of the car up while the front and rear are on scales (and then repeat with the rear) to find COG? Looks like it's too late for you to do it but maybe someone else has.
I though about it, but I figured changing the front and rear suspension weights and eventually an aluminum block would just throw those numbers out the window. My biggest guess is the COG height. Im not sure how you would even calculate that without mapping the entire car in solid works or a similar program.
Here is a simplistic view of how to measure COG
I wish I could post as an image but am no longer able to load images
Looking at the PDF attached above
I think you will find the base c3 weights about 2000 lb on the front and 1400 lb on the rear . Roughly
Bfit
Ps
But I think you have just put up an example to show how you can work this out
Bfit
Ps
I do like the idea of using a suspension analyser to work out how the geometry will function . A lot less guess work and you will get an idea of camber gain etc to get some performance out of your suspension
Having never done this or any other major suspension design before, Im excited to try it out. Messing around with the stock C5 pick-up points the analyzer shows that just narrowing it ~3", the geometry turns to sh!t. Im hoping to get both the front and rear optimized to work with the vehicle as best as I can :cool:
WAY in hell over my head guys, I stick to my 'tronics', 'lectrics'.......
you know, something DOO able.....:suicide::harhar:
Having been down the path you are now on, I highly recommend you check out the following link: http://www.lateral-g.net/forums/showthread.php4?t=42467 Ron Sutton is a genius when it comes to suspension design and he puts the concepts into very simple explanations. A couple things you should note about the C5 suspension is that, unlike old school thinking, the upper and lower control arms angle up (the UCA only slightly) toward the center of the car, producing a very long lateral instant center (swing arm) that actually limits excessive camber gain with travel. The second is that the lower control arm inner pick-up points are angled up toward the rear of the car. This helps produce caster gain with travel, which then translates into "good" camber gain when the wheels are turned. You are correct in noting that, as you narrow the suspension, the geometry changes. I ran into the same thing as I built longer control arms, and the geometry correction involved re-computing the heights of the pick-up points of the control arms to re-establish an acceptable instant center and roll center. I found it useful to do full-scale drawings starting with the roll center height I wanted to achieve at full suspension travel (the suspension height you anticipate during braking and cornering - mine is a high travel set-up limited by shock bump stops), then putting the data into Performance Trends to verify. Good luck with your project.
The following is in the "for what its worth" category and is how I approach defining the suspension pick-up points in a generic sense. It sounds complicated, but following your suspension program, it's not that bad. First, you have a few "hard" points already defined based on the spindle and tire width/backspacing you have chosen. Those are the wheel mounting flange height and depth, the lower ball joint center, and (subject to minor variation for camber adjustment), the upper ball joint center. Remember that the C5 suspension is designed for a deep backspace wheel to reduce scrub radius, so you will have to factor in things like wheel-well and fender lip clearance (especially at full compression) when you select your wheel. You need to be able to turn the wheel 27-30 degrees at full compression and roll. Do what you can to minimize scrub radius, but in the end, dynamic caster becomes more important. You know the C5 kingpin inclination angle (KPI), and your dynamic (at compressed height) caster should be 1.5 to 2 degrees greater than KPI for optimum cornering. The caster angle, the vertical location of the wheel centerline with respect to the centers of the upper and lower ball joints, and the fore-aft wheel centerline define the actual locations of the ball joints (the outer pivot points of the control arms). I enter the ball joint centers into the suspension program assuming compressed suspension height (i.e., with total caster at 1.5-2 degrees greater than KPI and initial camber at what I desire for pre-turn-in conditions. Remember, you will gain camber as the wheels are turned due to the caster. Then I would set my roll center at the height I want for a compressed suspension (1-2 inches -- less for road race, more for autocross). Roll center at ride height really doesn't mean much, it is the dynamic roll center that affects how the car handles. Draw a line from the center of the tire contact patch, through the roll center, inboard to a distance, let's say the same as the C5 (which is very long - 250 to 300 inches, or so). The inboard end of this line defines the lateral instant center point. Then draw a line from the upper ball joint center to the same instant center point. The control arm centerline inner pivot points fall on the two lines that run from the ball joints to the instant center at the appropriate control arm length. Realizing that you have defined the control arm pivots at their centerline, you still need to define the vertical location of each end of each control arm (front and rear). For these, I would start with the C5 relationships - upper control arm angled slightly down in the rear, lower control arm angled up in the rear. These angles define your anti-dive and the rate of caster gain during suspension travel. Raise the figure to ride height, and you can then see the control arm pick-up locations for fabrication. I actually build mock-up control arms out of scrap tubing and cheap ball joints so I can run the suspension through its travel and verify caster gain and the effects on camber at various turn angles. I also make all of my pick-up points adjustable so I can make minor tweaks later on if necessary. Hope this wasn't too confusing.
Pappy
Hey Pappy- Were on the same page, just different forums :amused:
Ive been submerging myself in Ron's posts over on pro-touring for the past few weeks. I was actually hoping for your input on the C4 rear geometry as I see you run a similar setup.
Pappy hello
Read your post. And just making things clear .
Bottom are in C5 IRS pivots upwards to the rear how ever the connection point angle upwards to the front.
I believe that is what you are saying in your post.
The bottom are at the connection points is a 9.5 degrees up from rear to front the
Top arm is 0.5 degrees down from rear to front and
0.3 degrees a side angle inwards from rear to front ( I'll have to check that as working of memory that may be overall angle )
My measurements are off one car only and there will be variations do to production tolerances
And these numbers are for standard width track.
I am interested to see where this thread goes
As I have a C4 IRS that I'm playing with at the moment as well as researching C5 suspension
The more players the more info we all get
It is posible to fit the c4 or C5 IRS. To a c3 at its standard width for the respective C4/5 IRS if you go to flares and use the c4/5 ofset rims
A C3 looks quite nice with 2" custom image flares and 12" rims under the rear
Hence I'm working on fitting standard width C4 to this C3 and C4 front suspension.
Bfit
I spent some time with Ron at the Goodguy's finals in Scottsdale, and we discussed rear suspensions in detail. He is and has always been a "straight axle" advocate and his race cars are based on a disassociated, offset three-link, but after watching Mary Pozzi's Camaro with the Art Morrison IRS at the Goodguys, he conceded the obvious benefits. Here are my thoughts on the C-4 IRS. You can generate the same suspension geometry (roll center, camber gain, degree of roll steer, etc.) with the C-4 set-up as you can with the C5 control arm set-up. The difference is that you have to deal with the axle shaft that is a loaded suspension member, but not really a big deal unless you break it. Four areas that can and should be adjusted to suit your particular application are: 1) length of the forward links. Longer is better as it slows down suspension geometry changes, but room is limited with a C-3 frame. 2) angles of the forward links to establish the instant center and anti-squat. I make the forward pick-up points adjustable much like a standard drag-race four link. 3) The length of the toe control rod. The C-4 uses a long link here which introduces some roll steer that "tightens" the car with roll to keep some bozo from backing it into the outside wall on an on ramp. Notice that the C5 and later shortened the rod to eliminate some of the roll steer. You can treat the toe control rod the same as you would the front tie rod when you establish the mounting points which allows you to control or eliminate "bump steer". and 4) the inboard end of lower strut rod needs to be adjustable vertically so you can adjust the roll center. This adjustment also changes camber gain, but in a high travel, low roll set-up the rear suspension does not travel much (a couple of inches), so roll center is more important than camber gain.
Track width is easy to adjust by changing axle shaft and lower strut rod length. Stock C-4 axle shafts can be shortened fairly inexpensively. I used custom built shafts from the Driveshaft Shop to handle some fairly heavy torque loads. You can run a fairly deep backspace wheel (7 inches +) with the C-4 upright without interfering with the forward links. I use a 13 inch wide wheel with 7 inches of backspace, and I widened my rear fenders to accept a 345 rear tire. One other note - if you shorten the half shafts too much, you get some fairly undesirable geometry changes with travel. In this case, it would be better to go with the C5 set-up where you can keep the suspension links (control arms) a little longer and accept a short axle (on CV joints) that is not acting as a suspension link. We did this on my brother's Jag 120 with C-6 suspension. The rear suspension was narrowed 13 inches!
Hope this helps. I've attached one photo of the Jag's narrowed suspension, and I'll put together some other photos to show some of what we have discusses.
Pappy
The criticism I've heard - and I could blame for an issue I have/had with my car is this:
Since the driveshaft is a loaded member, on hard corners the force spreads the carrier thus reducing the ability of the clutches to keep both tires spinning.
true? false? but given what you've said - would you achieve the same benefit as a C4 suspension by simply putting an upper bar and removing the c-clip?
please excuse the sentence construction, it's probably as stuffed up as my head...
I have not personally seen the posi clutch issue you describe. Several folks on this forum have tried various modifications to add an upper link - some better than others. I personally don't like sliding yolks in the axle shaft due to friction in the splines that sometimes causes unpredictable geometry changes. With big horsepower and big tires you put a lot of twisting forces on the splines. I prefer stout CV joints on the axle to absorb the minor in-out movement. An issue with an upper link using a C-3 frame and a C-4 upright is the lack of room for the link because of the position of the frame rail. Also, it is fairly difficult to adapt an upper link to the C-4 upright, although several guys have built custom uprights or modified C-3 stuff to accept the link. The same thing applies to using C5 control arms without moving the frame rails inboard (see the Jag/C6 picture above)
I have a rear differential from an 06 GTO that 1320gforce built with all the good stuff (and it howls like a banshee) - so this questions comes from "I have this on the shelf" and is probably one of those "you could, but it would still cost more than other options".... despite that I'll plow on -
why not maintain the C3 arms, and replace the differential with GTO, Viper, or even new CTS/Camaro center then adapt the CV joints?
The C-3 trailing arms introduce significant roll steer - that is the reason most guys (and GM as in the C-4) go with multi-link forward links and a toe control rod. The roll steer wasn't too bad with narrow, bias ply tires that you could overcome with throttle and just throw the car into the corner. A lot of fun, but not the fastest way around the track. With that said, I have been to several recent events and watched Danny Popp (72 Corvette) and Brian Hobaugh (66 Corvette) walk away with wins against some tough, late-model competition. Both are using basically stock C-3 IRS set-ups (stiff springs, modified roll center, and high dollar shocks), so it can be done. I watched Brian twist the end off one half-shaft in Scottsdale and fix it in time to make the final heat (which he won). Destroyed and replaced a $1000 JRi shock, but he still won. The apparent "trick" to both cars is minor modifications to the front control arm pick-ups, excellent caster gain with fairly high travel, big tires (315s front and rear), and superb shock valving.
BTW, the differential in the Jag picture is a late Camaro piece, and I am considering using a Strange Engineering S-60 (Dana 60) IRS differential that is used in the Art Morrison IRS. Very strong!
Care to share more details on the front control arms? Are they doing more than offsetting the uppers for more caster? Are they relocating upper and lowers?
Looks like they are going for more caster GAIN during suspension travel - spacing the front of the lower control arm down (putting a spacer block between the front of the control arm shaft and the frame), which causes more caster gain as the suspension compresses. Danny Popp's car had tubular lower control arms on it at the Goodguy's shoot-out, not the stamped lowers he had on it before. It also looks like they are using very high quality, adjustable shocks and, on the autocross, are using a slow rebound to pin the nose down through most of the corner. Watching Brian's car from the front, there is very little roll on corner entry and both front tires seem to be doing their fair share of the work. Brian in particular is dealing with a lot of scrub radius, which tells me he is probably compensating with lots of caster - it doesn't seem to be hurting him. Another thing I noticed, with the 200 tread wear rated tires are the very wide rims compared to tread width - not wide tires on too-narrow rims. I'll guess that some research has been done to optimize the tire contact patch with that tire. These are just observations on my part and do not reflect anything I was told by either driver. Oh, I almost forgot, the steering appeared to be very quick with the Borgeson steering boxes - so quick that during tight corners you could see the front wheels "twitching" like a dirt sprint car in response to the drivers' steering inputs. Looked perfect for a tight autocross track.
You point out what really got me thinking - Danny Popp's car. I've not seen it in person, so your observations are quite helpful. Seeing him spank the high-dollar muscle-car suspensions with the "old" Corvette system really does make me smile.
I know a guy with an 06 GTO that has a 1000 hp LS motor in front of his rear differential, and he's settled on a based-on-ford-9-inch designed center section and he has kept the IRS....
you've given me lots to consider - thank you.... we now return to our OP's thread :lol: sorry for the hijack
WELL, that makes me feel better about my lo-budget build, maybe not ALL the fun is lost.....
:harhar::cool:
Here is a modification I have been planning on testing for some time - just haven't gotten around to it. It is a way to eliminate the adverse C-3 rear roll steer problem without making major modifications to the car's frame. One solution is with the C-4 suspension (or Guldstrand mod), but that requires surgery to the frame at the front trailing arm mount, and the forward links are shorter than I would like to see. The forward links provide an "instant center" of motion (at the intersection of their extended centerlines), but unlike a 4-link set-up on a solid axle, do not transmit torque from the axle to the chassis. The C-4 forward links merely transmit forward force through the instant center, although they do transmit braking torque since the caliper is mounted to the bearing support. The forward links of the C-4 suspension can therefore be replaced with a "ladder bar" that uses the original C-3 trailing arm forward pick-up point. A C-3 trailing arm can be modified (if you prefer the C-3 bearing configuration) to do the same thing. See the attached "crude" sketch, for which I apologize.
Finally, a toe control rod can then be added to either the C-4 upright or to a modified C-3 trailing arm as shown in the sketch. Note: you cannot simply add a toe control rod to the back of an unmodified, rigid C-3 trailing arm because the suspension will bind (too many things swinging in different arcs). All that remains is to add a pick-up fixture, either on the differential or the differential cross-member, to pick up the inboard end of the toe control rod. I have a couple of extra C-3 trailing arms and I will build an example to test.
Something is wonky with that image. It won't show up, and when I try to open it in a different tab, I get a page showing that I'm not logged in to VM. :bonkers:
Sam,
I'm logged in and the image is presented as a thumbnail. When I click on it, it just expands it to a larger view. The only time I've had the problem you're encountering is when I am not logged in, and then it shows "attachment" at the bottom and it won't let me open it. If you can't get it, PM me an e-mail and I will send it to you that way.
Pappy
