keywestjack
- Joined
- Apr 24, 2008
- Messages
- 258
- Reaction score
- 0
When did GM go to SMC body pannels. I was watching a video from Ecklers and it suggests 1980. I have been told it was earlier.
Then what kind of bonding adhesive and resin should I use on my 77, polyester (for non SMC) or epoxy for SMC? The video said do not use polyester for SMC.
Evercoat SMC adhesive can be used as filler and it's compatible with fiberglass and SMC. It also comes in a 1 qt can so you don't need the expensive mixing cartridge gun :thumbs:
Your car is SMC. Danny
Although I don't know what SMC is, if I buy a repro panel for my 1970 as I'm planning, is it going to be "SMC" or is it going to be ????
Most repro panels are hand laid fiberglass, dunno if SMC panels are available from aftermarket suppliers or only GM "licensed" ...
You can tell by the price, if it's reasonably priced it's fiberglass![]()
THE C3 SMC IS NOT THE SAME AS C4 AND LATER SMC! You CAN use polyester resin on a C3. I should know, I have about a gallon of it on my 71 and it stuck just fine.
Call these guys:
http://uscomposites.com/index.html
I've ordered from them before, they sell high quality products and they not overpriced. They have several epoxy and polyester resins, see which one they recommend for SMC
I am repairing my pace car style front spoiler and bought a QT Bondo resin from the local store. That stuff is junk compared with the resin from UScomposite, it's way too thick and does not "wet" the mat as good as it should. If you don't force it into the fabric or mat some of it will stay 'dry'
