Steering by wire ???
DWncchs
Are the late model cars "steering by wire" ? I didn't know until recently the throttle was "by wire" and it looks as if some of the hybrids are "braking by wire" (which scares me) but STEERING ? :shocking:
My Saturn has electric assist steering and I get that but the owners of new Corolla's are reporting the car wanders on the highway,that sounds as if there is no shaft connection between the steering wheel and the front wheels. :amazed:
Sure would keep the lawyers busy....imagine the wrecks when someones car loses a battery/alternator going down the road? I doubt a car company would be so stupid. Wait...maybe Toyota would do it.:suicide:
Look, in jobs past I have been shoved around plenty by EMI/RFI, and there simply is NO group of tests devised by man or beast or computer that can replicate 5 million cars on the road with all the possible variations in this EMI/RFI enviornment...period....
that and plain AGE and grounds, rust, wiring, connections, assy techniques, plating on interconnects, you get the rong set of shit going on and the very best laid plans go in smoke.....
I would never have a car where the basic mechanical functions are done through computers....even the mighty Boeing had a tail rudder malfunction....
and they are some of the best engineering groups in the whole damn world....
I don't even care for ABS, tell the truth....
:crap::crutches:
I've been asking for weeks now why the hell we have to have electric gas pedals anyway. It's stupid. But of course the answer is the environazis/politicians mandated unnecessary laws all in the name of CAFE and "saving the planet".
Couple reasons. The first is a reduction in emissions due to the ECM being able to coordinate the fuel flow changes with the throttle changes. (The ECM no longer has to play catchup with the injector pulses every time the driver nails the throttle or lets up on the throttle.) Pretty much just an effort to deal with EPA regulations. The second reason is a reduction in vehicle weight and parts count. Several functions can be combined into one. The throttle body can do its normal function, along with replacing the cruise control hardware, and also any C4-like ASR/traction control hardware that might be used in the vehicle.
I'm not aware of any production vehicles being steer by wire. (Please correct me if there are any.) There are a few that have electric power assist, as you are familiar with, but the mechanical connections are still the same as previous steering setups (steering column, u-joints, and a R&P box). While it's certainly possible to make a steer by wire vehicle, it's what we used to call "lawyer bait". It's an item that's just too easy to be used by an ambulance chaser to sue you, even if the vehicle was not at fault.
:crap::crutches:
Yep they did. But it was a mechanical (worked by air pressure) limiter that failed- no electrickery involved. Other than the servos that shut off hydraulic pressure- and that was a pretty basic switch- once a specified air speed was reached it clicked off the servos to limit rudder travel.
I dunno man at 600 rpm the sparks are 40 per second...at 6000 it would be 400/second....400 hertz, a computer clock runs a minimum of what?? 2 Megs?? it's gone around the corner fell asleep got up had coffee before the next injector needs fire...
I dunno, servo motor is a servo motor, so the cruise is now on the throttle body directly....maybe I give it 1/2 a lbs saved....got more dirt on a car a week old, then that.....
As for ASR/traction control, I dunno, I have to ask why bother?? I been driving 50 years without it....course I don't have phone text either....
:crutches:
I don't actually know of any,my thread was prompted by many news reports stating that the electronic steering on new Corollas have the drivers reporting the car just weaves back and forth on the highway and turning the steering wheel does nothing. That "sounds" like there is not a shaft connecting the wheels and steering wheel.
The other thing I heard was about the Prius brakes and that they switch over from "the hydraulic brakes" with a momentary LOSS of braking. Switch over from what ? to what ? I'm "assuming" some of the braking is part of using braking energy to recharge the battery's.
I've done a little bit of Google research on these but really haven't had much time to devote and was hoping you guys might have the answers.
Yep, that's pretty much the exact reason I said. What I don't buy is the reduction of weight. You ever see what a race team pulls out of a production car to prepare it for track duty, and there's at least a couple pounds (sarcasm) of wires and computers and other unnecessary crap. I'd be really interested to see an ounce by ounce comparison between a mechanical pedal, cable and linkage vs. a servo pedal, wiring harness and servo inlet.
Now the Prius's are out of control and crashing,how much horsepower do these cars have ? The women's Prius accelerates from a stop (the width of the street) and takes out a brick wall ,come on ?????
The guy on the freeway is running 94 and says he "CAN'T" shift into neutral ??? Why can't the car be put neutral ? Does the Prius have a shifter or is it a button thing like on a microwave ?
The news said there is no key to turn off.
Guess I need to stop by the Toy dealer and sit in a Prius.
How fu##ing hard would it be to diagnose these problems to determine if they are mechanical or electronic ??? :bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit::bullshit:
OUNCES?? on something that weights 2000 lbs....what is the diff, and my point still stands that the computer is gone to sleep, woke up and had coffee by time that injector p/w needs changing....so that is not a valid issue, they'd have to prove that one....I think it's just plain cheeper....the cost accountants have had their say....
and yes, even on a olde tyme vehicle, like my '72 vette, or this 40 y/o motor home I'm working on, I have pulled about 50 miles of excessive wiring outta them, each one.....got a whole recycle bin full of wires, amazing....
of course some went back IN< but even with fuel injection I had wire left over....:rofl::crutches: I can just imagine a modern car....rather not, really, freeking nitemare.....
:club::tomato::rofl:
as for the column lock, isn't that electronic on some solenoid these days??
kill engine and lock column the same time or is it mechanical like on my olde '72 TT column??, and still no answers about the shifting, what with today's electronic trannies...are there any more mechanical cables into the valve body?? if it's all that computer shit and a bunch of solenoids....anything is possible....
:club:
t:
Torque determines how far you take the wall with you.....
:harhar::gurney:
My 03 Silverado is fly by wire. Not ONE issue I have heard of with these trucks. It's not the system, it's TOYOTA's design.
BILLIONS of dollars at stake here. They will let us know AS SOON as the LAWYERS decide they are ready. Not a moment sooner.:smash:
Whoa, this turned into a computer-hater-convention real fast.
As for the first question, I was told the big reason with why we don't have steer by wire systems yet is due to weight, complexity and cost. For something this crucial, you need the system to be in TRIPLICATE according to federal regulations.
However, this type of system allows a lot of flexibility in terms of how much better a car can be driven, by the average person, in a sticky situation. For example, the stability control system (which will be mandatory on new models soon) will be able to better control steering angle, just as the ECU can better control throttle by wire systems for things like traction control.
Obviously, the better trained driver would not need this and would be able to drive the car better without it, just like many arguments about ABS. However, this is a system for the common man.
Also, this would allow cheaper manufacturing of cars due to the MUCH less complex process of mounting the steering wheel on either side of the vehicle. From a design aspect, this is very nice.
As far as throttle by wire, there are plenty of cars out there (I'm not sure any new model has a cable throttle) have these systems in place and operate fine.
For this prius guy in Ca, I believe he was afraid to shift it into neutral, not that he couldn't. At least that's what they said on the radio this morning. He was afraid it would flip. Yeah, I don't get that either.
I also think a lot of people are afraid to pop it into neutral for one big reason: liability. For example, if you bring your car to a toyota shop with a freshly grenaded engine due to you popping into neutral with the gas pedal pinned so don't lose control of the vehicle, they may try to skirt out of it since you didn't lose control of the vehicle. There's no one but you saying the pedal stuck and nothing saying you would have lost control of the vehicle. Now, if you call 911 and lose control of the vehicle instead of popping into neutral, you now have situation more publicized and toyota may listen a little more closely.
That's my personal conspiracy theory...:hunter:
Back when I still did motor controls, and PC's were relatively new, we had "soft" interlocks, and "hard" interlocks. Soft ones were via programmable controllers, and hard ones via relays. Dangerous conditions were supervised via hard locks.
I.E., railroad grade crossings are still controlled via hard interlocks via relays. The circuits are all "supervised" via contacts. If ANYTHING fails, the arms come down. You have seen these down with no train around. This is a safety feature refined by years of practise.
Perhaps a "hard" interlock is in order here.
:smash::smash::clap: Yeh, no shit.....
:thumbs:
Agreed. This is what is done for throttle by wire. If anything in the system fails, the throttle plate goes to the idle position (closed) and you are able to pull over safely while gradually slowing down.
Sidebar: This is also why I believe Toyota when they say this is a mechanical problem, not software. The system has no way knowing if the pedal is frozen due to mechanical failure or the pedal is being held down with a foot.
However, what is the "safe" position for steering? If this fails while driving, you can't just lock the steering into any direction, or let it float. This is why with a system like this, there would have to be triple redundancy, either it be through 'soft' or 'hard' interlocks. I would assume a combination of the 2.
Probably something simple stupid, but they still haven't REALLY found it. So. Cal. cars around here that have been "fixed" are stilll failing.
True, but from what I've read/seen/heard, it appears to be a mechanical lock-up in the pedal. With that being said, I'm not a toyota engineer and obviously we simpltons haven't been shown exactly how it has failed.
Only time will tell...
