SuperBuickGuy
Wilwood D8, the problems continue
So I put the $80 lines I bought from Summit on the back, and moved to the front (and now I have "spare" front brake lines as it was cheaper to buy all 4 then just 2...)
looks nice, huh?
this is the "after" picture. The before picture shows the caliper won't clear the rotor. I had to put an 1/8" spacer between the hub and the rotor to get it to fit together.
Nice that they included bolts to put 2 of the calipers on.... would even be nicer if those bolts worked on 2 of the calipers. For those doing this update, save all your bolts, you'll need them. At least they're pretty?
Got the steering box back in the car
front end reassembled
To get a bit more lowering, I swapped the 1" block that was on top of the composite spring to the bottom
and started removing the lower arms to put poly in instead of the rubber
looks nice, huh?
