SuperBuickGuy
Interesting stuff - so the Sniper falls on its face just off idle when taking off from the line. It's mostly annoying because it's a rolling start so by the time I get to the line everything is peachy. Apparently Sniper has trouble with radical cams - and the fix - is shut off the self-tuning. Drove it today, and it's not perfect but it's at least 70% better. I have a couple other things to do (like start the self-correction at 1800 rpm rather then 2000 rpm) and I need to add a bit more fuel ... and remove some fuel from tip in (along with go through the logging I did today)... but I can race it now
temps, on the other hand... it gets to about 205 and should be at 200 or even 195.... changed to a higher flow thermostat today, might put Earls in it. It's not overheating, but it's also not in control. What I did do, though, was open up a vent under the nose and that really helped with highway temps - there it stays at 184-188 (and it was 90 today when I was driving it)....
I'd add an oil cooler but it's idle pressure is still pretty low - when I change the lifters after Optima, I'll probably add an oil cooler... that should fix it all
