That looks like pier paolos irsso here is the rear suspension I'm planning on using
http://www.corvettefaq.com/c3/6link/
and pictures of the bits....
and no, the stack isn't right - but it's the basic idea.
and never used it, built it for the C3 that's my avatar but then sold it and bought PF2. still have the bits, however, I cut them out of too-thick steel so they've become random scrap to use for other projects.That looks like pier paolos irs
I think the optical illusion is the start of something great. I've been considering all I've been talking about with an angled radiator and then - after seeing the ductwork on that car, thought, well why don't I put vanes on the back side of the radiator to straighten the airflow? I could, literally, hide increased downforce there by ducting back up to the hood vent (or simply aim the air back up towards the vent). Sure, it would slow down flow but the benefit of reducing the lift induced by the angled radiator might make it all worth it.SBG -
Thanks for the links - looks like you're right on the brake cooling NACA duct in the roof - not a wing section.
Nice optical illusion and willingness to "believe."
Now, I've got some sketching to do...
darn you.... lol... I spent part of this afternoon chuckling about the notion, then seriously considering it....Add a bit of Chaparral action to the idea... put 2 3000 cfm fans on the backside of your radiator to help straighten the flow. Then you have a "plausible" reason for the vanes/ductwork too. if the radiator is in a bottom sucker position -- all the better I'd think. Can't say how much to gain - but it is in the right direction.
it would be a bit or a paradox if we found that the hardtop cars could have better aero then the convertiblesAll good thoughts - I wanted to articulate the concept of a "roof" airfoil that the earlier picture looked like.
I "cheated" and just copied the arch of the buttress and roof line with no attention to the shape of the airfoil. Much work could be done here. (it was just a 10 minute effort by a low skilled CAD-artist)
And yes - it would need some shaping - or some clever use of a gurney, or vortex generators. Filling that area (on the rear deck) with airflow could "shape" the external flow and reduce drag - with less weight than a "fastback." Anything to reduce the drag from that area should be a good maneuver.
BTW the rear airfoil on the red "vette looks a lot like the F40 Fiero mods, don't ya' think?
No, you do not have to remove the glass or the outside weather strip....
the parts
getting close the bloodletting being done - but notice that the bottom hole isn't aligned - Chinesium strikes again. Nice touch that all the bolts are 10mm socket head
usually the problem is worn pivot points, not worn rollers (or worn teeth on the regulator - my problem). That said, you can buy an entire, wheel kit from most of the major suppliers.Interesting, this job is in my future. You don't need to remove the window but is there hardware (like rollers) that need to be replaced on the glass?
Nice video!interesting aero ideas on this...
