elkabong
Member
- Joined
- Mar 24, 2008
- Messages
- 13
I thought there would be interest in this. I have been struggling with feeding a 383 in my 84. On the dyno we noticed a fuel pressure drop from 20psi to 15psi with a TPI pump. Pressure started to drop off at 4000rpm and at 5500rpm the pressure was at 15psi. Needless to say this indicated a severe fuel delivery issue - the TPI pump should be able to supply enough fuel - I have a LT1 pump in the wings just in case the motor needs more fule. One way to cure this is to parallel plumbing the TBs. The regulator is a bypass regulator hooked up to the return side. I am also removing both regulators and will have a plate welded in place. The injector tops are at the weld shop and should be done in a couple days. Hopefully this setup will supply enough fuel to feed the motor so it can be all it can be.
I also plan on redoing the fuel lines to use hardlines once I get stuff setup. This was a exercise in getting it plumbed and working. The airpump at this point is nothing more than a pulley - it is gutted. I may fab up a airpump delete for the 84 sometime in the future.
![pplumb2sm.jpg](/proxy.php?image=http%3A%2F%2Fmembers.cox.net%2Fazc4vette%2Fvette%2Fpplumb2sm.jpg&hash=fb804fcfc21fcce444fa6cfaac92889a)
