My '76 restoration (long post)
Carburated Nihilist
City & State/Province
Montreal, QC
Hi guys.
If you please I may share with you my still short but already rich experiences with those 4 wheels sharks we call C3's.
Bought my first vette Spring '10, a black on black '76. I got this car relatively cheap, but I bought it like a noob. You'll see later.
Those cars are so visually amazing, they make you go nuts.
Let's call it the First Vette buying Syndrome.
I never experienced such a powerfull car. I found stock vette to be severely under powered, I mean for a sport car,
but this one...holly ****..
Sure enough, the guys had poured a lot of money on the engine and trans... for drag racing.
Imagine that, I'm a french who lives in Quebec, grown up with sticks on small econo car. Not enough you discover car in the past has 350ci engine and 3 speed automatic (only 3 wtf), but this one comes with a shift kit, and a line lock. I can tell you, this a ******* culture shot.
Paint was so so, black but over a original corvette orange, there was no "spiderwebs", but crack at some random point of the body.
The interior was original but baked, a new carpet (not completely installed).
The engine was very clean, aledgedly no more than 5k miles, a 350 ci bored .30 with pretty much everything forged, hi perf head, High CR, agressive cam, carb 850 cfm, hi-flow oil pump, electric fan, alum radiator ... The usual for a drag setup.
The trans has been rebuilt 500bhp-capable.
The frame looked, from what a knew, pretty good, dirty but solid.
Some leaks in the steering.
All in all the car was a work in progress still drivable. I knew I could learn how to fix a steering leaks, so the car would keep on getting better.
So I bought it.
And started my weekend-by-weekend restoration job.
My first fix/mod was the electric headlight actuator conversion. I got inspiration from mcspeed design, but simpler
The rubber hoses looked aged, and with the timing of the cam, I was not sure I would even get enough vacuum.
And it was in sync with my conception of the C3's, a stunning look that need upgrades.
Salvaged a hydroboost at the scrapyard for pennies, because at idle there was not much vac for the brakes neither.
Installed a Borgeson/Cheroke steering box. The steering system was leaking from everywhere, since I had to put some money on it anyway I opted for an upgrade. Rack system was too expensive and radical for me at the time and would have immobilized the beast for too long.
I then start the interior restoration:
-rechecking all the wiring to figure out why I didn't have interior lights. -Brought the tach to live, changed dash lights to led.
-tin-soldered a lot of crappy connections.
Dismantled and cleaned he vent system (and yet another missing part here)
-Bought on ebay pretty much every trim, because everything was broken, bubba-repaired and was holding by a-screw-or-two.
Took me some time to realize that I may have overestimated the quality of the car.
The interior was coming along nicely, but the more I upgrade/repair the car, the more I discover the true state of the metal below the car. I had to get to the conclusion:
the frame is shoot
After some time of discouragement, I decided to put the trigger : I'm gonna do a complete frame off restoration, in a 1 car wide, 1 3/4 car long garage, no less.
Bought a nice and cheap POR-15ed rust-free frame on Ebay, turned out this is from a forum member (thx again tsarno!)
put it in my garage:
yeah, I know the place is messy, but it's getting better
Then put two hoist on my not-that-high ceilling
No way I could use a single hoist setup of a engine hoist and still getting enough clearance below to dismantle the frame. I had to raise the car as high as possible.
Disconnected all that needed to be (their is a text file on the net/forums that list them all, invaluable)
Invited a couple of friends, and ******* did it!
You see the new frame a the bottom of the picture, you get a idea of the space, of lack of.
Watching your car separating itself in halves gives you a eery feeling.
Here is where I should have learn more about C3 before buying it.
Doh!
On the other hand, the engine is cool
Then I started the rebuilt process with the front train.
Since you always forget something, I opted to restore one side at a time, a Frame swap is so much cooler than a frame resto for this.
So I would start dismantle one side, and upon reconstrution I would still have a mirror copy on the old frame. Even with the AIM I found this setup very handy.
-new moog balljoints
-VBP steering rebuilt
-Moog 470lbs coil spring, bilstein shock, poly bushings.
Everything have been grinded to metal/etched/POR15ed.
SS-sleeved O-ring calipers on their way.
Here's the result:
A lot of these part have been bought from forum member, thanks a lot to them.
Here is a first draft spreader bar, not sure I won't have to change it.
Now I'm on the trailing arm, bitchy thing, lot of rust.
After screwing a couple of sawzall blade I took my grinder and cut both end of the T/A bolt, then drill out a couple of millimeter on the outer side. Then out can twist out the arm.
Will get the bearing setup rebuilt in the near future by a famous forum member while I'm installing the Johnny joint I bought.
Wow, and 6 month ago I didn't know shiat about cars... except which one is the sexiest.
Sidenote: A couple of things a newbie like me learned (sometimes the hard way):
-Join and use the vette forums
-Get the AIM!
-Get a impact wrench
-Get a torque wrench
-mark everything you remove from the car
-mark down every wire/cable you disconnect
- this site is awesome
Thanks for reading.
That's all for now, I'll keep updating with the progress.
Rust day! (have your tetanus shoots before reading)
Hi Everyone, here's some update.
This weekend have been very productive, apart from finishing my front and rear bumper assembly put back together, I managed to remove my second trailing arm. Since this operation is a major PITA, I thought I should document my method which is, IMHO, simpler and faster that the usual sawzall method.
Here the nasty bugger:
The cotter pin just felt into dust, the bolt came off gently, this will be the only one to collaborate :
Disclaimer : I'm not planning to reuse this frame, so I went a little berseck on it. I'm confident that you can operate with much less damages made to the frame itself.
The first step is to grind off both side of the TA bolt :
outer side
inner side
Then center punch and drill the outer side :
I first drilled with a small bit then when to bigger ones
The vibration of the drilling and a small crowbar allowed me to rotate the aligment shims. They eventually poped out.
Once you've drilled out the bit of the bolt that holds the TA to the frame, you just have to twist the arm, and it will come off easely.
Rust day, part 2: beware, gross
I'd like to share with you my experience of electrolytic derusting since I'm pretty happy with it.
Here's my trailing arm treatment:
The setup is ghetto, but you don't need to have it fancy, I will eventually get disgusting anyway.
Used a old laptop charger, the positive wire is tied to the metal bar, the negative wire to the part you want to treat.
In the bucket I have water and sodium carbonate (washing soda). 1 spoon per gallon of water.
If you don't have sodium carbonate, take sodium bicabonate (backing soda) and heat it in the oven at 200° F for one hour.
Before putting it into the bath I roughly cleaned it with a wire brush. The aim was not cleaning it, rather expose as much rust as possible.
If the electrolysis can reach the inner layer of rust, the crap that sits on it will go at the same time.
12h later :
Now that's what I call gross.
I ran the setup outside, I don't think that the quantity of hydrogen released by the process is enough to be a threat, but this is not a risk I want to take.
It's almost freezing outside, and surprisingly it didn't stopped the process. So far so good, I bet in the middle of the Quebec winter I won't be the same.
Here's the arm once washed :
The picture don't do justice to the result, the clear spot on the treated side of the arm are bare metal showing up. The black is
One dried, the treated part will re-rust in a matter of hour, I wire brush it quickly and treat it with phosphoric acid spray.
The good thing with this method is that is goes everywhere, the TA has a lot of unreachable areas, like the inner of it or all the gaps between the crappy point-welds. With elecrolysis ALL the rust will be eaten.
Disclaimer: this is not a actual guide, get yourself documented, I might be wrong.
Well, not ALL hippies are lazy assed......
U did all that **** in just 6 months, and have a 40hrs/week job, I presume........you did a hell of a lot of work there in a very short time period....more than most guys by a wide margin.....:nuts::bounce:
Theres much more.
I'll tell you he aint lazy, pretty focused in gettting this car ready for summer.
Thanks Gene, what's posted here is work from august to october. I indeed have a 40h/week job, as a game programmer. The good think is it only drains the brain, but leave plenty of body energy.
Hi everyone.
I'm not posting updates as soon as I would like, but the thing is, the more time I spend posting, the less I spend working on the Vette
I've been progressing at a satisfying pace.
My trailing arm are now entirely dismantled and I sent to Gary "gtr1999" Ramadei what he need to machine the rear bearing assembly. Since I'm in Canada, we choosed the lightest setup possible. I only sent the spacers, the shims, the spindle housing and the flange.
Of course I will have to do the reassembly myself, but I didn't want to pay big bucks to send my complete trailing arm assembly. It only cost me 35$ to have them sent to CT, postal service rocks!
I the meantime I received the part I ordered, and started installing them :
Here are the all new parking brake assembled:
And the Stainless sleeved calipers, with brand new bleeders and o-ring pistons installed:
I took care of my fuel tank, which is still in very good shape. It only has light surface rust, and the inner parts in pristine shape.
I'm also starting to treat my header, just surface rust. They'll get some high temp paint and insultation wrapper is on its way.
Today two friends are coming to help me put down the differential-halfshaft/rear spring assembly. When it's done, only the motor remain on the old frame.
I've been waiting for weeks to secure a deal on borrowing a engine hoist and I'm starting to doubt I will ever happens.
So if you're in the Montreal area and you have one to lend for a couple of day, let me know.
Done, the differential has been removed thanks to helping hands from Christ and Sovan, my buddies and active restoration supporter
I'm glad I bought those car dollies ahead of need, they turned really helpfull for moving the tranny in the cramped area.
Since only the engine and the diffy remained on the frame, we decided to lower the back of the frame with the dollies already in place.
Once the diffy was landed, we unbolted it then jacked back in place the frame. The diffy detached itself with its own weight.
Once the engine it swapped I'm ready to let the frame go
By the way, If you're in Montreal and looking for a free frame, let me know. The kickup arches are rusted out and the body mount gone, but all the front is still nice and strong. I won't refuse a couple of used part in return
A milestone somehow
All in all it's been a very productive weekend.
One of the few thing the PO did right was to have the differencial rebuilt. It's not perfect, but still it's not a piece a rust so I decided last night to mount it back the way it is.
Here is it, with new poly bushing.
Spend the whole Sunday grinding my headers, what a PITA
With some hi temps ceramic paint they now look much better. I hope I won't forget to "cook" the paint once the engine is running again, no way I could find oven big enough to fit those.
So yeah, some king of milestone, the old frame is now completly empty.
I now just hope I get a engine hoist quickly or I will be kinda stuck.
E day
Today was a big day, engine came for the old frame to the new frame.
Hopefully 1Michel came to the rescue, lending me his engine hoist for pretty much how long I want. Michel, you rocks :thumbs::thumbs::thumbs:
Quiet a challenge in the cramped garage.
Not been easy, but we made it.
Here the picture, made by Kouya, who has a prety good taste when it come to framing the moment.
Enjoy
Here are the heroes of the day :
Jeff, mustang lover
Sovan, who never missed a WE, my top notch restoration buddies
And your servitor
To come next: Tom's big big surprise.
Stay tune, thanks for watching.
Watch out, master@work
Received some update from Gary "GTR1999" Ramadei.
He has finished preparing my rear wheel bearing assembly.
What is cool with Gary is that he sends you tons of picture of his process.
Here's for example how he reconditioned my spindle flange.
I ask him to just focus on the mechanical side of them, parallel grinding them and cleaning the outer diameter. He could have done a complete sandblast/repaint of them, but I opted out in order to same some cash.
The package is leaving his shop this monday, can't wait to start reassembling them, one of the lastest missing piece of the rolling chassis
Good progress this WE
Hi everyone.
This weekend have been the occasion to put back a bunch on stuff.
Quiet rapidly part make their way back into the new frame, freeing some precious room, for the big operations to come.
First of all, I was sick of the picture quality I was having with this old 1.3mp canon. Rugged, it was very practical for reference picture, but for posting purpose I now switched to a more modern camera.
Ok, Fisrt I'm done cleaning the exhaust. Ceramic hitemp paint all along, and the new hiflow catalytics.
The cat are 2 1/2" model. My exhaust line it 2 1/4" but by using the pipe flange on one side and with an adapter on the other side they fit together nicely.
Then the spare tire carrier. A hefty dose of cleaning, cleaning and repainting, and voila. Not brand new but definitely good looking.
Ok, I still need the upper cover, someone on the forum told me he could get me one from a scraped '80. We'll see, in the meantime on less enormous part out of my way.
Finally as you saw, comes the fuel tank
Did the drilling to put back the support at the correct place for my tank size
I had to weld new square nut to the tank straps.
I also still need to check the internal rubber blader for leak, but given the very nice state of the send last time I checker, I'm pretty sure it is still goodL
Those element took me weeks to clean, repaint and change the decayed fasteners, but today was the rewarding moment they get back into the frame as almost complete module.
Tom "Santa" Sarno
phew, it's been a hell of a week end, in the best way possible.
Now It's done, I can tell the story I've been holding for some time.
This week end I went picking a new birdcage I've been given.
Not a typo, given, for free. By Tom "Santa" Sarno, my own great Samaritan
Looks like Tom appreciated the good use of the frame I bought him month ago, and contacted me with this awesome offer.
But for those that read my thread, you know that my garage is tiny, with on entrance blocked by the body hanging in the air sitting on wood beams.
So I had to devise a plan.
Saturday I bought three 2x10x12 at home depot and built a giant dolly, using the car dolly as bases. It has to be low, my garage has a steep enough ramp to cause problems.
It's basically a giant frame, with to higher beams on the middle for the rocker channels to sit on.
Here seen for inside the engine bay
I'll try to get a better overall view of the body dolly.
I reused the support beam to finish it. No room for wood surplus.
So the plan was to go get the new birdcage, then pull the old body out of the garage
Once out, we put it aside and the pavement (now neighbors KNOWS i'm crazy).
Then slowly back up the trailer down the garage with the car.
Then once the trailer coasted to the new frame, with all the friend I could bring, when dropped it on the new frame.
Then put back the old body at his place.
Close de garage door, et voila!
Enough for today, more details about the new birdcage condition soon (in two world : absolutely gorgeous).
To continue my ode to my generous donor, I'm posting picture of the good shape of my new birdcage.
The one I'm replacing had so much hidden rust and nasty patches it gave me nightmares. This one on the opposite make me all warm in the pants everytime I inspect it.
The windshield is almost rust free, just a tiny patch of surface rust on the lower corner.
The orange spot you can see it factory paint showing up through the black coating.
Look what I found under the dash
Same thing for the body mount, a little of rust, a lot of sand.
The only place that ever saw water are front of floorpan and exterior side seatbelt reinforcement pocket.
Water must have stayed inside the car for too long, but only inside, because as you can see the underside of the floor pan is still sporting large area of unpainted, unrusted steel area.
Sand, no rust, this can is a desert can for sure, I didn't know you could have steel that old without even a little surface rust.
Guys I'm so happy to start rebuilt my vette around such a piece of clean metal. Sometimes I put my finger in small recesses only to feel the cold and hard surface of unharmed metal. Damn, my pants again.
Ask say before, my exterior seat belt are rusted out.
So I cut all the bad parts :
I can hear you from here yelling : "you suck at welding"
I know, I know.
But it's hard to do nice welds with an arc welder. However it's sturdy enough to break way after the floor pans themselves.
Haven't been updating this thread for a while.
Thing is, the more I post the less I work on the Vette.
These lastest weeks have been really busy ones.
First I had to do big preparation work, consisting of a complete cleaning of the underside of the birdcage and the firewall. brush off rust, treat and paint.
Then I was set for the reassembly
The floorpan :
As said before, the floorpan of this new birdcage did rust from the inside, down to a point the front part of the driver side is paper thin. So with some paint remover and a sharp chisel I removed all the thick paint and the rust stuck under. Wire-brushed the remaining surface rust and treated it. Topped that with some fiberglass. Not the prettiest fix, but now my floorpan is firm and sturdy.
The wiper compartiment.
One thing that surprised me the most when looking for a C3 to buy was the poor job done here. You could tell the guy on the assembly line just had a couple of minutes to do the job. I removed the wiper support and clean off all the black goo I could. Some paint over that and It already looks cleaner.
Sure I could have sanded all the hard beads, but time is scarce and I want to work fast.
Need to cut some corners from the show car path.
Then I put back together the wiper assembly after some good cleaning and painting.
I took care to reapply generous beads of sealant.
Wiper motor.
I opened it, clean the gears and repacked it with a good load of white lithium grease. The plastic cover was broken in two. I put the pieces back together with tape of the front, then I filled the crack from behind with some bumper repair epoxy, the one that stays soft. Once cured and the tape removed, you could barely see the repairs and the piece feel strong. Here again, some cleaning and painting.
Pedal setup.
Cleaning, prep'ing, Por15ing.... as usual
Same thing for the hood latches :
I've put the rear compartiment door, temporary, until I received that insulation kit that took so long to get shipped.
I also reinstalled the rear wiring, including the central storage light and the electrical component hidden here.
I dismantled the heater system today just to discover another Bubba disaster.
The core was leaking bad and as a repair, the PO just simply cut whole system, yes, I didn't cut those hoses, that's how it came out of the car. I now know why the heating didn't work. NIB core found on ebay for 25$, on its way.
Ok, back to work, I was to pack as much work I can in those holiday Santa brought me.
I'm still confident I can have the whole interior put back before I get back to work. *finger crossed*
Happy new year.
Trying hard to keep the pace.
Yesterday the interior harness landed in its new home. It's just a layout phase, I'll have to remove the duct to reput the new heater core anyway. Last summer I already did a complete interior tear down and wiring review, so everything was already labeled and I start to get familiar with it.
Madvette's insulation kit finally arrived yesterday. So today I took care of the rear of the interior.
Then put the new carpet. The kit was actually inside the car when I bought it but the PO didn't installed it.
I won't have to deal with those rear storage box door anymore. Ok, I will put new door frame at some point, but that's a detail.
At least something finalized, something I can call done.
Feels good and rewarding.
I'm just a grade 8 bolt away from installing the F-body seat belts I bought last year.
Meanwhile...
It's been a week I order my new heater core I need to complete my interior rebuild. The tracking # still tells me the package is waiting a the departure post office. Not sure it's still actually there, but it's still a bad sign.
Damn, I hate to be stuck.
So this leaves me with time to take extra care of some "details" and to document my work.
I decided to refresh the air inlet door mechanism.
My main concern was the foam seal, or what remained of it.
I the looked for a replacement material that would be inexpensive and durable, and I came up with some flat silicone mat sold has cookie sheet. If it's tough enough to withstand oven heat, It's tough enough for me.
Once cleaned and painted, the door panel is riveted on the sheet. Too bad it's not black, but hey, it's at well hidden part, who cares.
Then I did a rough 3/8 cut
After a bunch of fitting test I came up with this cut
To have a freely moving door while having optimal sealing. I admit, It could have been to little bit better of the back corners
A little shoot of silicon oil on the rubber membrane, and voila.
Good to go for a decade or two.
Default The 16 layers of Vette Archeology Yet another productive weekend. My mechanis
My mechanist made me a custom tool to assemble the outer bearing of the rear wheel.
Sure Just a tube of metal, but machined to the perfect diameter for pressing the bearing.
We started taking care of the front clip, that will go to my new birdcage, Sovan was stripping its paint while I was removing it.
The stripping was a easy job, the paint, or I should say the paints, was so thick it would flake of in huge pieces.
Seeing how easily it was coming off, Sovan devised a tools for the job.
A razor sharps metal spatula.
I had to show you that :
I grinded a bezel for you to see. Yes, 16 layers. You're seeing it back to front. And the PO told me it was a originaly orange corvette. Well, after being at least burgundy and metallic purple. You can't see from this side but the paint also sports several cases of "just paint over the clear coat" *facepalm*
Removing the front clip was another story, we're not done yet, but I wanted to share with you a method that worked well so far, and is IMHO very gently with the body parts.
I used this portable hand saw:
But with the blade reversed, to work like a Japanese wood saw, you actually cut on the move back. Once I started on one side, I would shim just enough for the saw not to be stuck, and I slowly just through the bead of sealant. It's easy to feel and see when you're reaching the fiberglass itself and need to reajust your trajectory.
Of course I used a heat gun to get the sealant soft.
One side is done and we didn't put more crack that it already has.
Phew. Probably the most stressfull task so far.
Good and bad news
Yesterday was a bag of mixed feeling.
The good : my heater core arrived, the tracking still tells it's at the departure post office, I guess you have to take those with a grain of salt.
This is a brand new one, bought from our trusty Willcox but never installed. At 25$ that's a steal.
Now I can reassemble my interior once for good.
The bad : I kept of removing the paint and what's under is worrying.
You see those two area near at the back of the front clip where there's still the top black paint layer:
Well, turned out under that there is a mofo thick layer (around 1/16") of soft yellow repair crap stuff, and under that the fiberglass is bible paper thin.
I'll post picture this evening.
When I talked about the 16 layers of paint to my friend (actually 18, the pink-salmon stuff on the picture turned out to be one of the two last layers before I actually reached the fiberglass) they joked about the fact I'm removing structural strength to be body, looks like it was not such a joke afterall. *sigh*
Damn, he got me
Thanks guys, I'm honored to host your post. This is definitely badass industrial process.
In the meanwhile, the newbie I am got caugth on Ebay. You remember my leaky heater core? Well I rushed to buy a replacement on Ebay. It was an allegedly a "1968-1979 Heater core" bought for Willcox.
On the picture it had the bended tubes, not the two 90° tube like the no A/C car. So I thought is was the right one.
Yesterday I brought it to the garage, just to realize the mistake I made blindly trusting a Ebay seller :
On the left the new core, on the right my leaky one.
Hey, Willcox, since I know you're around could you help me identify this piece? My guess is that it is a '90-something corvette heater.
Looks like my interior completion will have to wait for a while. No big deal, this weekend I'm finishing my trailing arm, and I still have enough works in progress to not be completely stuck.
Still this is a tad depressing.
Hopefully LeSkid showed up with a sixpack and we sipped beers while talking about the project. Just what I needed.
Ok, time to put a "WTB heater core" on the forum.
#@$*§ !!! (insert favorite swear here)
Man, not a good week.
We finally, Sovan and I, removed all the gooey crap on the side of the front clip, near the windshield.
Thick layer, average 1/16" with peak at 1/8".
Not done yet.
Under that, some sort of dark resin that get shiny and oily once you heat it, I bet some that never entirely cured.
Once done removing, the grim reality showed up it ugly face:
t's been fractured and put back together in authentic Bubba style.
I'm still wondering how such damage could happen, and really don't know if and how it's fixable.
JJ day !
Resto makes sad those day, let's do some mod instead.
A while ago, I bought those Johnny Joint.
Today I went to Michel garage, Michel is restoring a '72 BBC near Montreal, he proposed his son who is professional welder to help me put them on the trailing arms.
I used his sandblasting booth to clean the tip of the arm.
Steven, Michel's son, welded close them
I Cut a 2" hole in place of the former axis.
Place the JJ
Weld it
Cleaning
Result
Seat belts
In the meanwhile, here's my seat belt setup, in my usual style : cheaper, newer and safer.
This is the classic mod, using a pair of Camaro '94 (maybe '93) rear seat belt, bought a the scrapyard for 50$.
Basically all F-body of that era make good donors.
As advised by a Vettemod forum member, I searched for 90's GM male buckle, they are compatible with the stock female buckle, so you can still use the seat belt sensor.
This is not the best buckle, but it does the job, I'll search for a better one when I have time to roam the scrapyard.
Here are my reinforcement installed, epoxy glue and rivets, and a grade 8 bolt , maybe overkill, but better stay on the safe side.
It's a one tensioner setup, less fancy, but that make one less device to fail.
My stock system might still work, but it looked so aged I didn't want to take any chance, and given the price of restored one, this was my only option.
Awesome job !!!! Keep the updates coming :thumbs:
I noticed on the first photo of your headers that they're discolored brown(ish) ... this color is normal for 400 series stainless after a few heat cycles. 304 stainless is not magnetic, 409 is magnetic but you feel a difference between that and carbon steel... take a magnet and check...
On your brakes: did you verify good contact of the mating surfaces between the two caliper halves? I've had a pair that I rebuilt leak and since then I use ink on the surface to check for good contact.
Not sure the headers are stainless, I had to remove a good deal of surface rust, I know even stainles can rust, but that much? Still I'll try your tip.
No I haven't checked the calipers surface.
Basically you spray ink on one side and see if all is transferred to the other, right?
But isn't the small o-ring supposed to do the sealing?
I'm still got to get the 7/16 fine thread grade 8 bolt for installing them, so I'd definitively check this out too.
Thanks, you was right, that not on CF I could get advises that good.
Pressed in!
Ok, it's done. My rear spindle assembly is done. phew. That was not a walk in the park, because I made the mistake to install the seal backward. I initialy thought the right way, but a the last minute, just to be sure I check the haynes manual, and what I saw indicated otherwise. I realized that when sending the picture to Gary.
So I had to disassemble everything, extract the outer bearing (thus ruining it), and get a new set of outer bearing.
Hopefully I had a spare pair. Not the original USA made timken bearing, but I'll change them next winter.
I did the jog a Guy's mechanic shop. He's my dedicated mechanist, he's a old wise guy, sorry to see nobody will pick up his business we soon retire. He's using WWII era machines no young mechanic can operate. He gave me tons of advises all along the process, on how to hold tool and to thing the proper way.
So it was a great teaching at the same time.
So, here's the proper procedure when you get the economical way with Gary (sending him only the spindle house and the flange).
Pack your bearings, this is a neat tool Gary talked about in on of his paper
Grease is synthetic Timken, bought from Gary too.
Install the outer bearing
The spindle housing received a generous amount of grease, not filled up to allow expansion.
Install the outer seal (the right way!)
Insert gently the spindle, at put the assembly under the press. I used the tool I talked about a couple of post earlier.
Obviously, don't press onto the studs, there a huge nut found in my mechanic shop.
Back from the press, slide in the spacer
And the shim
And the bearing
Your bearing might need some pressing, not really mine, I just had to press by hand with a metal tube. Never hammer!
Instal the seal
The spindle shield
changed all the little pieces like the flange Shield
Put the flange
Then torque the nut at 100lbs. The nut didn't lined up with the cotter pin hole, to I remove the nut and grind it a little with some sanding paper on a flat surface. In two attempts I was good.
Put the cotter pin, et voila
The spindle can be turned with a finger, I feel no play at all, well done M. Ramadei.
the Johnny Joint installed:
drilled and NPT-tapped the JJ shell, and made a slightly bigger hole for the zerk.
With the greasing zerk here, no need to use a drilled ta bolt. I didn't feel good about having hollow bolts on trailing arms.
I shimmed the rotor down to 0.003" which is more than enough with o-ring calipers, and while at it checked the rotor play : 0.002", good job Gary.
Once done, the way for putting back the TA was clear.
The TA bolt received a generous dab of antiseize in order to exorcise my TA removal nightmares
I'm adding to my buy list a pair of rubber ebrake protection and a pair of rear rotor.
I don't even try to clean then, they're done, good enough for now but will be changed soon. As soon as payroll permits.
Disclaimer, I'm really not sure the calipers purge valves are at the right place, I haven't check that yet.
I can now see the time the car is going to seat on its tires, when the suspension will feel the car weight for the first time.
Can't wait.
400 series (409) stainless is the "cheap" exhaust stainless.... stainless usually means 12% chrome or higher, 409 is as low as 10.5%. 304SS has 18% chrome for example.
primary reason for using 409 stainless is cost, I just bought a 4 foot section 304SS and that's $60 at jegs.... a 409ss U-bend is only $25 (mandrell bent)...
Info on 409 stainless:
http://www.suppliersonline.com/propertypages/409.asp
On the brakes: yes the O-ring is supposed to seal but if it is not clamped properly due to unparallel surfaces then it will leak. I now use a sharpie on one half and then put that half in a vice, then rub the other clean half firmly against it ... you'll see if it takes the sharpie ink off evenly or only on one corner.... I use a small file to knock down high spots.
