Reinforcing some aero stuff Pappy pointed out earlier on his Viper regarding wheel well exit ducts... I have a McLaren 720s In the shop with some cool wheel well aero.
Two huge ducts on each corner of the bumper feed coolers, and then exit out the side of the bumper AND the wheel well towards the side of the car.
Now I see, the air exits in front of the tire and is directed outwards. Kind of like the F1 in some respects where they create that vortex.
The largest opening is below the orange marker light, right? It kind of blends in.
Make new rocker moldings out of thin aluminum which are 1 to 2 inches longer. This will act as side skirts keeping flow out from underneath. Lower is always better for side skirts.
Creative use of black paint could disguise how low they are.
Also, the spare tire area is a mess, a diffuser would be too obvious for your goal, at least a smooth under belly would help.
We're on similar wavelengths here. Several years ago I pulled the stock rocker panels off and made 2" lower/wider replacements with Lexan sheet, and painted them semi-gloss black. I like the looks better, and so far no one has seemed to notice the change.
I had an aluminum bellypan on the car for a year or two, but my unscientific perception of the setup convinced me that the weight (about 30#) was hurting me more than any actual aero improvement was helping.
I've also looked into doing something at the rear, but so far I can't justify the weight of a diffuser. My current direction is to reduce the slight understeer I have, and ignore the rear until it becomes the limiting factor during cornering.
Are you running a rear sway bar?
RTJ
This has nothing to do with what your talking about, but
Have you put the body back on your chassis? I did the trailing arm adjusters that eliminates the shims and now the that it’s done I’m wondering if the body is going to fit?
Do you know if it does?
