SmokinBBC
Good news is I have to burn some remaining vacation days b4 year end.  So I started the interior replacement.  First up new door panels....easy first job...
So I get the passenger side done, no problems. I went with bare panels and just transferred hardware, cut/fit, greased mechanisms....yada yada yada...looks great.
On to the dirvers. Same procedure. After I greased the mechanisms, I checked the key lock. Slammed the door...maybe a little too hard. Anyway, the door latch jammed. It happened to me before a few years back. Since I had the door panel off, no biggie, just pressed the lever and released the latch.
For future reference, it is the lever that the screw driver is resting on that you push down on to release the latch. You can probably get to it through the top if your door panels are on, but you need a a very thin screw driver and probably a lot of patience.
Good news is you can buy replacements...bad news is that they are friggin expensive!
Anyone rebuilt these things? Are they salvageable? The door lock lever on the mechanism is not fully going up, therefore not allowing the latch lever to do it's job.:search:
