I have replaced the door latches on my 68 with later (74?) latches that I cleaned and lubed with lithium grease. Before replacing the latches, the doors closed pretty poorly. They would "bounce" open (from fully closed) about a 1/2 inch before the latch would catch.
Without changing anything else, I replaced the latches. Now you have to lean into the door and body slam it to get it to latch. If you try to close the door normally, most of the time it just bounces open. On the bench, these latches work really well. I have not found any information about rebuilding these latches.
The hinges are tight (new bushings), the doors are aligned with the latch.
