curiousity: 383 ci, intake ? and carb size
MYBAD79
Moderator
City & State/Province
sunny Florida
While I am (for now) happy with the performance of my 383 SB I am curious how much "better" it would be with better matching components.
Up for discussion, here's my setup (the heads, intake and carb are leftovers from my 350) :
4 bolt main block, 383 stroker crank, forged pistons, 9.8:1 CR with Edelbrock RPM heads 170cc runners, 64cc chambers, thin head gasket (.028") and decked block... cam: comp 230-236, .510/.520 lift 112 LS, stock 1.5 rockers (roller tip)
Intake: Edelbrock Performer, Carb: Edelbrock 1405, 600cfm
I guess it's obvious that the intake and carb are not the best choice for a 383 with a relatively hot cam.
Questions:
- how much will I gain when I install a better intake and a 750cfm carb ???
- am I starving the engine or run it too lean with the small carb ???
Spark plugs look good.... engine runs an feels great..... again: the heads, intake and carb are leftovers from my 350.. if I had a bottomless wallet I'd dump them in a heartbeat for something better (Brodix. Dart, did I mention AFR?)
A dual plane intake will give you a better bottom end. They're pretty flat too. If you get a tall open plenum single plane, the bottom (low) end will be dead as a sack of hammers, but it'll wake up as soon as the cam starts getting into the lower end of it's designed power band. You'll also need to jet it a bit toward the rich side from where it is now. A carb that has a higher flow will help too. A 750 will probably be just a bit big for low and midranges, and not quite enough for big RPM power.
Go with a Performer RPM intake and a 750 cfm carb.
The L88 hood will be fine for a RPM intake and I already have a Holley 750cfm carb on the shelf (old, needs a rebuild)
I am not going to spend the money on the swap any time soon - I have the steering rack conversion and the trailing arms to do first.... but I am curious what would I gain from the intake/carb swap ???
Am I hurting the engine with the current (small) carb ??? Too lean at higher RPM ??
How bad is my current combo from a pro's point of view ??? OK, I know it's not perfect... I had to re-use the heads because I didn't want to spend another $1200 at the time... just curious how much better/more powerful could the engine be with better heads/intake /carb ???
Hard to say how much you're leaving on the table, but everything in your combo is too small for a 383. A 383 likes 190-200 cc intake runners in the head, the cam is just a little small in duration, but matches the comp. ratio pretty good. The intake and carb. are more suited on a 327. The 600 cfm carb. won't make it leaner or richer, it will just be down on power. I'll bet you are down 75 hp easy.
A friend over here has a 383 with 190 runners and an Edelbrock air gap intake and is running a Edelbrock 1405, 600cfm, the motor seams to run healthy as is. Maybe a 750 cfm carb will give him a little more at the higher RPMs but how often does anyone rev there motor that high on the street?
I agree with what he said. All seems like it can be a little bigger. Going from 1.5 to 1.6 rockers will make the cam seem to attack faster and wake the car up a little.
I'd do the carb last. IMO that is the least of the issues.
I am going to disagree slightly with you guys. I think that his heads are too small for his displacement and camshaft. Getting a different intake and or carb is only going to have minimal gains.
I wouldnt be looking at an RPM airgap, I would be sticking to the performer airgap and his 600cfm carb is fine. Maybe switch his cam for something smaller like 218/224 and maximize the low end torque.
I am running an Edelbrock Air Gap Intake with a Holley 750. Low 13's at the track, good manners on the street. I could probably get into the 12's with an aggressive tune up and drag radials, faster still if I switched to an automatic, but WTF, I like it like it is.
[/IMG]
Hey, B2B, recognize the V/C's?
And before you guys tell me - I already got rid of the dangerous POS gas filter and got a solid metal one.
I agree as this engine with the small runners and small cam and rockers your not going to consume enough air to make a 750 carb work.
You may see a bigger differance going to a HP 600 Holley over the Eldy carb.
Here are a couple of 383' we have dyned with 600 carbs
http://www.chevelles.com/forums/showthread.php?t=106715
Here is one we dyned with a 600 HP and a 2925 super victor.
Thanks guys. Looks like the heads are the biggest problem... I sortof expected it .... eventually I'll need some better heads..... but as I said, for now the engine runs fine and I'm ok with the power - feels great :cool:
These Edelbrock heads are good for .575" lift so my first mod is going to be the 1.6 ratio rockers ... any other set of heads will be supporting more lift than the edelbrocks so the money for the rockers won't be wasted...
How terrible is this Performer intake that I have ? I "heard" it's barely better than the stock cast iron intake ???
If I recall correctly professional products intake makes more HP than an eldebrock
I have two of them myself and the castings are excellent, I don't even need to gasket match them
I've heard that the Performer is a lighter version of the stock cast iron manifold.
Ok, so there's "some" improvement :lol:
The rockers are a quick and easy swap but I'm thinking the Performer intake will be limiting (or eliminate) the effect of 1.6 ratio rockers. I better do the intake and the rockers together.... then later worry about the heads.
FYI... I just finished a build using Edelbrock RPM heads and intake with a Holley Street Avenger carb. (670cfm) using a dropped base air cleaner. It fit under a small block stock hood.
who sells these ? I was looking at Jeg's catalog and they have the RPM manifold and a Weiland Stealth high rise - the advertized numbers look a lot better than the Performer intake....
Karsten, I was talking with Dick Murray a few days ago and he said he will match Jeg's prices. BTW...I was looking at their intake manifolds today and they had an Air-Gap hanging on the wall. This was their Palm Bay store. Check them out with a look see.
If you end up switching the cylinder heads an opening up the flow of the engine then you may want to look at an annular version of the 750 when it comes time to change the carburetor out. It will have airflow similar to a 650 but have the top end performance of the larger 750 all while having good drivability and throttle response.
Welcome Tech at Barry Grant:hi:
Time to update this old thread..... Lol.... I have since then installed a polished RPM air gap intake and a Edelbock 800cfm carb, played a little with the advance springs in the dizzy and re-jetted the carb a few times.... Now it runs great, lots of power and I am seriously considering a rev limiter as it just wants to keep going, had it to 7000 a few times :D
And you can't wipe the grin off of your face...
I never had mine to 7K but I am told I should push it there. When are you taking it to the track?
:drink:
:drink:
Just replaced the body mounts so now it's finally back on the road..... I really don't have to push a lot to get it near 7000.... it's not really intentional either, in first and second it's just very quick reving that high...... I really think I need a rev limiter, no point going past 6200 or so, I'd hate blowing up this engine.....
:drink:
I come from the old Pontiac school of engineering gimme 550 ft lbs at idle.....I want to move NOW not wait till 8000 rpm's come along.....
:shocking: call me impatient.....
Yeah, better heads would be awesome but for I have to say I'm really happy how it runs..... Now that the body mounts are replaced I can actually drive it again.... Might change the oil this weekend and put a few miles on it :D
One question, I thought the cam has a point where the HP drops off, so what advantage is it to rev past that point?
BangkokDean;111661 One question said:
No point reving past that, it's just that in 1st and 2nd gear it revs up so fast that i sometimes don't shift quick enough ..... Rev limiter would make it safer :)
