“the LT1 and the LT2 weigh the same, 472 pounds with fluids. The extra weight comes in part from the block-mounted oil tank and the redesigned crankshaft, which has a slightly longer nose to accommodate the scavenger”
“a 454 with aluminum waterpump,heads, and intake you can get down near 650LBS”
