SuperBuickGuy
loaded question. I've been playing with this ever since I put an electric water pump on my car. The biggest problem (and this from an issue I had with an FJ40 with a 350) is if there is a valve in the heater circuit. If that valve is closed, you'll get air pockets trapped under the thermostat (which means, at best, a late opening thermostat). There is a solution, many heater circuits have a bypass type valve (meaning, if the heater circuit is closed, water goes back to the other end of the heater circuit). I've used that on my FJ40 and it works pretty well. I'm trying something similar here with my Corvette but I'm a week from really give it a full warm up and seeing what happens....I know this is old, but I have a question. Would it be a problem to run the bypass hose from the bypass hole in the water pump to a different hole in the intake? Say the heater hole to the left of the typical bypass hole in the intake. I am using AN fittings on everything and that short hose is a problem. It's a 70 ls6 454
