I really like the looks of that.... I am not getting hot right now but later down the line i plan on adding a pair of turbos and want a way to get more air in to cool things...... Who makes a cood one that is bolt on? Or am I just better off attaching something to what is under there...... if there is anything there.
I made mine from a cardboard mockup. It mounts using the vertical bumper piece holes and two extra holes I drilled closer to the outside
mine has worn away some but you`ll get great gains in hi speed stability with the cheap factory plastic spoiler....
my car is so low the spoiler "wears" on the race track, I like this one....your car is awfully high in the air too....lowering it will help.
http://ecklers.com/product.asp?pf_id=A2983&dept_id=1435
what material did you use? can you take some pics for me?
this one?
or is this one better
http://ecklers.com/product.asp?pf_id=10219&dept_id=1353
I don't know which will look better and perform better on my car
Looks like you hit someone...
I've got the fiberglass Pace Car replica spoiler on my '69. I like the looks of it, and the car's high speed stability is very good, A side benefit is that the sides of the spoiler seem to direct the air outward from in front of the wheels, creating a slight low pressure area around the wheels, which helps draw air out of the wheelwells and the brake rotors.
