MYBAD79
Moderator
Short block: 86+ (roller cam) 1pc rear main seal, bored to 4.030", 3.75" stroke forged crank, forged KB pistons with 18cc dish, Comp hydr roller cam with 230-236 dur and .510/.520 lift. I bought the short block assembled.
![100_1925Small.jpg 100_1925Small.jpg](https://data.vettemod.com/attachments/15/15099-234bbcd95f5eef9d98095f959d4db42c.jpg?hash=I0u82V9e75)
![100_1918Small.jpg 100_1918Small.jpg](https://data.vettemod.com/attachments/15/15100-2000da8032ac8dc9f7b1df071fd7c305.jpg?hash=IADagDKsjc)
Finding TDC, the pistons are .010" "in the hole", .015" was machined off the deck surface (standart deck height is 9.025", center crank to top of piston is 9.000").
![100_1941small.jpg 100_1941small.jpg](https://data.vettemod.com/attachments/15/15101-2d367cb062a736890f961c4f5310b706.jpg?hash=LTZ8sGKnNo)
Melling HV oil pump and hardened drive shaft:
![100_1957Small.jpg 100_1957Small.jpg](https://data.vettemod.com/attachments/15/15102-4d4a2a206f302e73d53d610319bd3fad.jpg?hash=TUoqIG8wLn)
Oil pan mounted with FelPro 1pc gasket, timing cover, balancer and crank pulley installed:
![100_1976Small.jpg 100_1976Small.jpg](https://data.vettemod.com/attachments/15/15103-0f9b512e75ab7c1e1b4cb6f7a9b8168c.jpg?hash=D5tRLnWrfB)
I cleaned and re-used my Edelbrock heads. With the 64cc chambers, the decked block and a thin (.028) head gasket the CR is close to 10:1
![100_1986Small.jpg 100_1986Small.jpg](https://data.vettemod.com/attachments/15/15104-58ed9f371a3184e816c366fda49309a8.jpg?hash=WO2fNxoxhO)
Heads installed with ARP bolts, water pump and pulley installed:
![100_1994Small.jpg 100_1994Small.jpg](https://data.vettemod.com/attachments/15/15105-7bfedcfd7ade5fdb549dc456dc65e22e.jpg?hash=e_7c_XreX9)
Intake (Edelbrock Performer) and dizzy installed:
![100_2003Small.jpg 100_2003Small.jpg](https://data.vettemod.com/attachments/15/15106-5165306c25d9db17d7a5aa7def8021c4.jpg?hash=UWUwbCXZ2x)
measuring pushrod length:
![100_2007.jpg 100_2007.jpg](https://data.vettemod.com/attachments/15/15107-9706d242b4bc6954edf78784dc7fff78.jpg?hash=lwbSQrS8aV)
![100_2011.jpg 100_2011.jpg](https://data.vettemod.com/attachments/15/15108-3626e5e4d692e1fea1d101b133b259e1.jpg?hash=Nibl5NaS4f)
Valve cover and tranny installed:
![100_2088small.jpg 100_2088small.jpg](https://data.vettemod.com/attachments/15/15109-ad439dfffff00c11231773e8f212dc13.jpg?hash=rUOd___wDB)
Almost done:
![100_2263Small.jpg 100_2263Small.jpg](https://data.vettemod.com/attachments/15/15110-3e99bcebe27ead741a0f2f514f12d3c4.jpg?hash=Ppm86-J-rX)
![100_2264Small.jpg 100_2264Small.jpg](https://data.vettemod.com/attachments/15/15111-8d03dec5d2e5c1aba55636e77ddecf41.jpg?hash=jQPexdLlwa)
Done:
![100_2277Small.jpg 100_2277Small.jpg](https://data.vettemod.com/attachments/15/15112-b13b67bd947fe63e2b6285b0cf41733f.jpg?hash=sTtnvZR_5j)
Almost done:
Done:
