1958 MGA Coupe
Thanks
Every so often you need to put time into upgrading shop equipment. I have been contemplating this since the lift was installed and this weekend was the time to do it
It’s a 42” long metal brake that I made Maybe 12-15 yrs ago and it’s big and heavy , made from window lintels on the 1950s brick houses they are tearing down around me steel is 3.5x3x1/4
The idea is to mount the metal brake to my lift ramp as a stationary tool and store the top piece next to it. Eric O and I brain stormed some options on it and in the process of mounting it became clear what the path was
Because of a previous mounting application I had to cut new openings into the top angle iron so it could go over the hinges, previous application had the tall leg of e clamping angle iron at the back
Pictures in reverse order, final product with example of clamps
Showing how close the top brace is to the folding part
Drilling holes using a step drill after drilling a 1/8 pilot hole
here it is mocked up with the top piece next to it
Mocked up
This week we will give a test run I need to make an extension hopper for the pellet grill
Today was the day to use the metal brake mounted to the lift and figure out a clamping methodology
The task at hand was to make an extension hopper out of 18 ga steel from an old industrial shelf for my pellet grill. The extension hopper better locates the pellets so gravity does it thing and you always have pellets over the auger tube.
The shelf and the hopper , luckily I have three of those shelves and it became apparent immediately two of them are getting cleaned and painted to use as assembly tops for my metal welding table and my sons welding table. They have a fiat side and flip it over and it has edges so stuff doesn’t roll away
The shelf has a great pre made edge I will use for two sides
The idea is to use only the 24x36 sheet
Two identical bends for the two sides and you use the holes in the magnets to clamp
And the top is cut from the base , mock up welding and test run today before full welding, I might add a handle for the temp probe base unit to hang on
And I have some ideas for a finger brake clamping system for the metal brake
I need a new grill and have been considering a pellet grill.
Pellet grills are great this is what you want
An ash bin easily accessible, a hopper easy to empty, the flame guard easy to move from the out side, get the insulated cooking insulation
I have had 4 pellet grills and still have three.
One step closer to finishing the metal brake clamping bar
Final design
https://hosting.photobucket.com/width=960&height=720&fit=bounds[/IMG
Cut and mock up
Tack in place
And mock up fitted to ramp
I need to source the bolts and nuts and add the gussets
I grill , bake (pizza) and smoke on my pellet grill
Ok let’s keep going. My grade 8 5/8 dia bolts came the other day and the vevor mag drill today it has a magnetic base and uses Weldon bits
Let’s drill some holes and mock it up. , let’s drill some witness marks in case the tape gets ripped off( it didn’t)
Lots of holes for a variety of clamping options but I have only 10 bolts
Give me lots of space, use a cutting oil , it self feeds the cutting oil and I used about 3/4 ounce
The twist drill chuck is interesting it uses a tapered shaft
Took about 25 minutes to drill those 19 holes
Now drill the hole to mount it on the ramp
And next effort will be tacking down the nuts to the clamping bar
Now we weld the nuts in place, put them on a bolt to grind the sides to shiny metal, hold them in place on a bolt and weld the flats
Only thing I may do next time is to clamp a bar across the back so spacing is uniform
I think I will use copper pipe caps with green sticky grease in them on the end of the bolts
I have a rounded bend and a sharp bend side to the middle piece
How do you like your vevor mag drill? They seem to be priced better than most.
I bought it for this project $169, free shipping and ten. Weldon shaft cutters, those (19) 5/8 holes took 25 mins to drill, self lubricating. I love it and was too late to this party
They have two cutter designs the Weldon shaft with two flat spots or a quick release “Noki” or something like that cutter. Those quick release cutters are really expensive.
Let me find the Black Friday link
This is the one but the 25% discount isn’t applying for some reason
Thanks, it looked like it did a good job on your brake, but thought I better ask.
The 25% discount is back now, the self lubricating is pretty cool it uses a floating center pin that when it’s depressed the cutting fluid drips to the center of the core cutting bit, I am not sure it lubricates it self using the twist drill chuck. I like it enough I would buy it as a gift for my boys
