bobs77vet
beautiful day today high 60s*
sand the doors one more time
thoroughly clean them, a paint job is only as good as the prep work
first coat self etching primer
and the black higher build primer. funny thing was the doors were not painted under the hinges....so this time around that area will get painted before the door gets hung. that may be the first car part i paint the body color.
i guess my next task will be to start cleaning up the dash. its still accessible.
 A six-terminal switch arrangement which serves to connect one pair of contacts with either of two available pairs of contacts. Its abbreviation is DPDT switch. Also called double-pole switch (2)."  if you look at Barneys site it has the schematic diagram explaining how the relays work inside of the turn signal relay.
		 , did you add rust to that hinge plate?
