the floor boards are original design and they were 3/8 plywood originally. these are 1/2" and 5 ply. originally they were painted black.
finsihed drill the holes
heres the weld nuts you can see it tells what size hole to drill
i have never done this before an i bought the spot welder for this project so lets play around some. i drill the hole and clamp the weld nut in place
use a grinder to remove the rough edges underneath and to give a clean weldable surface and unless your name is Brutus make a platform on the dolley for the welder to sit on
thats what it looks like
i use a long bolt to wiggle the nut.....if it breaks i do it over again.
a right angle grinder with a small wheel does the trick for the grinding
the spot welder tongs will not fit inside the heavy frame channel so we will mig it up
these just say for me to mig weld the hole's
welded and ground down
and if you screw it up this is what it looks like
done with the main floor boards. i need to think about how i can make a more uniform clamping jig just for the spot welder.
