1956 Corvette
mfain
Las Vegas/Phoenix
Several members have asked for construction shots of my '56 project, so here goes. I will group the pictures by area. The car is set up for a big block (eventually a 515 inch Dart aluminum motor) with the motor set back 12 inches. The first pictures give an idea of the motor location -- the cowl vent cover is removable for distributor access. The next photos are of the under-hood scoop which takes air from in front of the radiator and feeds it to carb and the oil cooler (mounted in ductwork in the left fender panel).
The next photos are of the aluminum firewall between the fuel cell and the passenger compartment (required by several sanctioning bodies), the fuel cell area with dust cover (aluminum top cover not installed), and the location of the battery cutoff switch.
A better picture of the aluminum firewall (fuel cell to passenger compartment), the trunk with carbon fiber panels (the hole in the floor has a CF duct that routes air from the side scoops to the differential cooler), and the beginnings of the Woodward steering column installation.
I Just gotta LOVE your wind tunnel on the 'GARAGE' set of pix there.....
trailer, 90 mph......all those tell tales on it.....:thumbs::smash::smash:
I would have been buying shop fans.....
:eek::twitch:
To answer a couple of questions: The transmission is a TKO600 Extreme (.82 fifth gear) from American Powertrain. I've also included a better picture of the Woodward r/p. I don't have pictures of the brakes on the car, but they are Stoptech ST-60 (six piston) front and ST-40 rear with 14 inch floating, slotted rotors. The wheels are 18X13 rear and 18X11 front HREs. The radiator is a 31 inch, dual pass Ron Davis model with dual Spal fans.
Geoff,
It falls in pretty much the unlimited classes -- it doesn't meet the maximum horsepower per pound rules for most sanctioning bodies, and the motor set-back is too much for others. It is just a good, safe track day car (club events) and will work for things like standing mile events and the Silver State open road stuff. I built it to road race for fun without worrying about points, but I kept up with all the safety requirements (cage, fire system, etc.) so I wouldn't be denied entry anywhere.
Whooaaaa. love the IFS w/ Woodward rack. Attention to detail is awesome, like how you tucked away the cooler and the patterson tank fits into the heater box. Very very nice
It has been a while since I posted, but that didn't stop the work. I completely redid the front suspension - now high travel, low roll with every pick-up point- adjustable on slugs. New, longer control arms, JRI shocks, new stout sway bar, new Sweet R&P, etc. The hard part was setting it up to accommodate 335 front tires with 4 inches of compression and 30 degrees of turn. That takes a lot of room! I have attached a few shots of the front inner fender panels to show what it took to make the room.
Great work. What rear end set up do you plan on running?
Right now it has an IRS - C-4 uprights, custom links, Driveshaft Shop aluminum axles, and a Tom's C-3 differential. I built a multi-link set-up with C6 uprights, CV jointed axles, and a Strange Differential, but I haven't installed it yet. I will probably run the existing set-up until I break something, then switch. Click on the "(6)" next to "My photos" in the upper right corner of this post - one of the photos is of the suspension.
Pappy
Announcement on radio this AM, 1953 Corvette #1 rolled off the Michigan assy line on this date.....
been a while......:smash::loveletter:
