I won a forged GM crank off of Ebay for $200 bucks. Its a 1053 forged crank out of a circle track crate engine. Hot!
So 1 step closer.
Here is what I am now considering:
(Parts in Green I already have)
1053 forged circle track crankshaft (supposedly 44lbs)
Scat 7/16 cap screw rods
KB dome 3.25cc dome pistons (11.5:1 SCR, 8:1 DCR)
GM 12370847 Hyd Roller Camshaft (crane 234/242 camshaft)
OE Hyd Rollers
Mcleod aluminum flywheel
Fluidampr
Pete Jackson Gear Drive
Titan Oil Pump
Custom Oil Pan
1996 4 bolt main truck block for OE Hyd Rollers
Hooker Sidepipes
750 speed demon with annular boosters and vacuum secondaries
Dart Dual Plane
Dart Pro 1 200cc platinum heads with straight plugs and 64cc chambers
Mallory magnetic breakerless corvette distributer with tach drive
Mallory hyfire 6 ignition box
Mallory Coil
Mallory Fuel log with pressure regulator
Mallory Fuel pump
Stewart stage 3 water pump
1.5.1 ratio roller rockers
Modifications to above parts
Rear coolant passages connected to front cross over
Coolant ports under siamesed exhaust ports on heads connected to water pump
Short fill in block
Other efforts:
Convert to manual brakes
3.73 or 3.9 rearend
New SPAL controller
Oil coolers w/ moroso sandwich adapter
On going efforts:
FIA headlights
Putting my interior back together
AC Delete kit
Stuff to liquidate:
Race pumps 150psi fuel pump, and carburatored boost referenced regulator
crower 1.6 ratio roller rockers
Crower 6" billet rods (supposedly they all work together but 1 rod is definitely newer than the others)
Ferrea 2.02 and 1.6 valves +.1 in length
misc carbs and parts
Weiand 7546
Weiand 7547
Weiand team g
AED pressure regulator billet aluminum mount and inlet kit w/ holley regulator
Completed efforts:
Kirkey Racing Seat installation
Shark Bar and harnesses
So 1 step closer.
OE Hyd Rollers
Fluidampr
Titan Oil Pump
Custom Oil Pan
Hooker Sidepipes
Dart Dual Plane
Mallory Coil
Mallory Fuel pump
Short fill in block
Other efforts:
3.73 or 3.9 rearend
New SPAL controller
On going efforts:
FIA headlights
AC Delete kit
Stuff to liquidate:
Weiand 7546
Weiand 7547
Weiand team g
Completed efforts:
