Thanks for the reply Mrvette,
I checked both Lowes, Rona and Home Depot and couldn't find any,
Anyone know where I can purchase the spring in the picture? I've checked most vendors and nobody seems to sell them.
Being from Canada we have Home Hardware instead but it's worth a try.Try ACE Hardware. They actually have...hardware.
I thought of that but didn't know a source for bare round metal.Make your own.
Wrap steel wire on some sort of cylinder, harden it, try it.
Repeat, changing loop count and/or wire size until correct strength is reached.
I thought of that but the tension was too high.[I made one out of this: http://en.wikipedia.org/wiki/Clothespin
Look for "piano wire" or "music wire", it's an quiet hard steel wire, RC hobbyists use is a lot.I thought of that but didn't know a source for bare round metal.Make your own.
Here in Canada, we don't have many around, the closest is maybe 45 minutes away and i doubt they'd let it go for cheap. It's all about supply and demand here.Another idea...call one of the several Corvette breakers.
It's worth a try, I check the hobby store next time I'm at the mall.Look for "piano wire" or "music wire", it's an quiet hard steel wire, RC hobbyists use is a lot.
I found them, in Canada!
http://montreal.kijiji.ca/c-cars-ve...Handle-Assembly-Spring-NEW-W0QQAdIdZ289841270
Here in Canada, we don't have many around, the closest is maybe 45 minutes away and i doubt they'd let it go for cheap. It's all about supply and demand here.Thanks for the replied guys.Another idea...call one of the several Corvette breakers.
Call one in the states. It shouldn't cost that much to get them across the border.
I called two today and they told me to come down and take a look, well that's not possible. Another said they probably have it but don't want to take the handle apart just to sell the spring. I can keep trying.Call one in the states. It shouldn't cost that much to get them across the border.
That's the same spring that Denpo found and it's not the same spring if it's part # 2653.Or try this in Pennsylvania, they have your spring
That maybe my other choice but I've found that shipping to Canada is worth more then the actual price of the door handles.Just buy a 15.00 set of handles off ebay with the spring ... end of problem
I don't have a droppy door handle, that repair would need spring #2653 from Corvette America. My existing spring broke so it's not repairable.I'm assuming you have a lazy drooping door handle. Maybe you could rebend the existing spring to get more tension. I'm curious if you have to remove the whole thing to replace the spring. I have the same problem going on so let us how how you resolve it.
