I am using a VBP dual mount rear spring on my 65. For some reason I can't seem to get the rear ride height up where I want it. As I tighten the spring end bolts it just seems to bend the spring. VBP says get a stiffer spring but when I put the current spring on the stiffest setting the car rides too hard and the ride height still will not raise where I want it. I can jack the the car on the strut rod inner bracket and the car goes up and ride height changes. I have offset rear control arms with poly bushings and strut rods with heim joint ends .Thoughts?
Thanks
Tom
Thanks
Tom
