Pypes exhaust system with X-pipe
With all the nice work you do, you want to buy an exhaust system? Why not fab it yourself?
You don't bend pipes, you go and buy stainless, straight sections and weld elbows, way, nicer than anything that's bend.
I have done several that way, you will need a tig welder to do nice welds but you can get a super clean look with Mig also if you are any good with that. If you have the skills mig can produce some very clean results. Just use argon/co2 mix for wetting.
This is a tig welded one, welds were not wire brushed or etched so you will see the reddish scale still there.
Here's a topic about it:
http://www.vettemod.com/forum/showthread.php?t=86
