Red
Hi Red, nice to see the photos you took of the Patriot heads at the Murray's Speed and Custom. These heads are as you indicated not CNC ported, but just gasket matched, probably by hand. I have not inspected these cylinder heads myself, but it seems like they have a reasonable flow as cast for mild street engine builds. I’ll try to do some work on my PROCOMPs next week and hopefully I have some more information to post as I progress. If you have some more information about the Patriots Red, I’ll appreciate sharing your findings.
As for the roller cam; I don't think that the 3970010 block is well suited for such. I would choose a flat tappet cam to be safe.
Arne
I never did get to see the Patriot head valve pockets, but think thay have been ported. After talking with a few other engine builders, they say the CNC porting is OK for FI cas, as the spray amomizes the fuel. Carburetors need the rough tool marks to help in this process. The CNC porting is too smooth for a carburetor fueled car. I'm going to look into this some more. Sometime in October I should be ready to buy my heads.
Recently, I spoke with a CF member who built his original 73 Corvette two bolt block using a cast crank, Edel 64 cc 170 heads, CC roller cam .510 and Holley 750 carb. It was dynoed at the builders shop to make 440 HP. My high nickle 010 four bolt block should do similar with a more aggressive cam and 190 runners in the heads. The two piece MS block will take a roller cam if you use the more expensive bar type roller lifters. My block will be decked, just like the engine built by the member and used as an example. It runs fine on 93 octane PG with a 10.25 CR. This is my plan, but anything can happen. Right now I'm still trying to fully understand the work done on the Patriot heads I'm looking at. I need to see the valve pockets. If it isn't fully ported, I may just do a set myself and save a little money.
A concern with porting an aluminum head is removing too much material. Aluminum comes out real fast and that is my fear. I've done iron heads with great results. My experience with aluminum, using my aluminum burrs, has been scarry. Maybe, it was just a soft alloy, but it was gone in a flash.
