- Joined
- Mar 30, 2008
- Messages
- 3,080
- Reaction score
- 42
- City & State/Province
- Clinging to my guns and religion in KCMO.
I need to plumb up a PCV system for my street rod '51 truck. My present selection of parts on the engine doesn't accomodate that, so I expect I'll have to get fancy here. I'm using 60s vintage finned Corvette valve covers (with no oil cap or PCV hole) and a late vintage Edelbrock manifold (which doesn't have an oil fill tube like the older intakes). This is just a toy vehicle, so I don't mind popping off a valve cover each oil change to fill the pan. But that still leaves the PCV issue. I don't want to molest the valve covers, so I'm kicking around three other options.
Drill/tap a hole in the intake behind the carb to vent the valley area, feeding into the PCV valve and into the carb. Short clean setup. But, I don't know if there's a lot of oil spray in there, and I would need to weld in a baffle setup under the manifold.
I kicked around doing the fresh air source plumbed into the fuel pump plate area, but at first glance it doesn't look like there's space to run a tube/hose into that area. Hopefully I'm wrong.
A second fresh air source I'm considering is the dipstick tube. Making a Y connection into the tube, or a short extension at the top of the tube might work. I don't know how much the crank throws oil splash into that area while it's running, though.
I pondered valve cover spacers to put the PCV plumbing into, but they're expensive, and I don't care for the look of them.
Final option that has occured to me is placing a fresh air inlet into the front half of the intake. Haven't considered all the up or down sides, but this option/placement is a more direct connection to the crankcase/sump than at the top of the valve covers.
Just looking for additional thoughts and opinions here.
Thanks,
Mike
Thanks,
Mike
