- Joined
- Mar 30, 2008
- Messages
- 3,077
- Reaction score
- 38
Trying to figure out a quirk with my mom's car. The engine will start up every morning, and run great (smooth, good accels) while we're driving around town, but when the car sits after being shut off warm it frequently won't start. Give the car 20-30 minutes to cool down and it starts up fine. The car has been to the local GM dealer and got worked on for a full day, but they couldn't find a cause. To their credit they only charged us for a fuel filter, which was due for replacement anyway. So now I'm trying to figure out the problem.
I initally thought the problem might be the fuel pump relay or the transistor in the ECM that turns on the relay. I took the car out for an errand to get it warm and then shut it off (under a shade tree in case I had to work on it). After I got back to the car about 20 minutes later I tried to start it. Nothing (it cranks fine, but no fire). I swapped in a relay from my truck and tried it again. No difference. I removed the relay and shorted the fuel pump to battery (eliminating the relay and ECM transistor). No difference. Crap. I was 95% sure this was the issue. I then opened the gas cap in case there was a vacuum or pressure, and it sounded normal. As the car cooled down it would try to start, but quickly die. The way the engine was misfiring sounded like a shortage of fuel, as the misfires weren't sharp like when a spark is randomly missing. I tried to come up with some scenarios where the IAC or MAP sensor is malfunctioning, but I don't think they would cause this particular non-start issue.
I assume the fuel pump is fine, as the engine has plenty of smooth power when I try to accelerate.
I pondered if the issue is the DIS ignition module, but presently rule that out as the engine runs smooth until it is shut off. So far I've had good luck with the engine starting right back up when I shut it off. I've only taken it for two test drives so I don't know if it will always immediately start up again.
It's only failed once while running. My sister was driving it last week down the highway for about a half hour when it died. I wouldn't restart. Once it had cooled down for about an hour it started back up and she drove it back home. I'm now trying to figure out the problem.
I have access to another MAP sensor and DIS module cheaply at my favorite junkyard, but I hate to just throw parts at it without a good technical reason. The temperature thing makes me think there's a solder issue somewhere, but why doesn't the problem show up more often while the car is actually running?
So, if you have any thoughts on what I may be overlooking please let me know. I'm next going to attempt to check for any malf codes if I can.
Thanks,
Mike
Thanks,
Mike
