CrossedFlags77
Active member
- Joined
- May 13, 2008
- Messages
- 34
While cruising Ebay I found some extremely inexpensive tubular a-arms from some stock cars.
http://cgi.ebay.com/ebaymotors/UPPER-A-ARM-9-3-4-X-3-4-OFFSET-NASCAR_W0QQcmdZViewItemQQ_trkparmsZQ7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem5ace0f501eQQitemZ390004166686QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Looking at them, the length to the ball joint is only about an 1/8" or so from stock which would just mean more initial camber. Also the cross-shaft mounting dimension is off 11/16 of an inch but it would be pretty easy to mill out the extra material needed and run a small spacer to fill the gap. You can also get different offsets to provide more or less caster. Sound like a good idea, or am I missing something? At $6 a pop it can't really be a bad buy.
