RobRace10
Member
- Joined
- May 13, 2008
- Messages
- 19
- Reaction score
- 0
So I have started to run my car 69 (427/390 with a little head porting, Comp Cams Extreme Energy XE274H, stock intake) a little harder and it seems to be running out of fuel at about 4000 rpm. It starts laying down and sure feels like fuel starvation. If I lift for a second or so and then step on the gas it will come back for a short period so I assume the bowl is refilling.
So it is a correct original Quadrajet carb for it and I have AN lines and a billet fuel filter. I have checked the fuel filters, the tank was spotless inside, new fuel sock, new stainless lines. I have an older Edelbrock Fuel Pump HD62 that I don't know the history of. Everything else was new since the rebuild. The carb had a fresh rebuild and seems to work perfect otherwise unless I stand on it for more than a few seconds in any gear.
So I opened the carb and the float level was set at about 1/2". I raised it up to about .3" and that seemed to help, but then I started to smell gas. I dropped it down a little and the problem has come back worse than before. I did also open up the fuel pump and don't see anything obvious but I will order a GM Performance pump as I need the opposite side inlet and outlet as on the Edelbrock HD62.
One other thing I have noticed is I'm building pressure in the tank, yet I have a vented cap. Not sure this would cause an issue, but just another FYI.
So anybody have any suggestions as I need to fix this! HELP
