I thought aircraft were 400 hz, WW2 stuff was anyway.....
I think your correct. I haven't done any high frq stuff in a long time. I do know the rules change. Mucho impedence in a circuit.
OH hell yes, any ET can tell you about weird **** happening to any coil/iron frame anything when various a/c freqs are applied to it....
much less if you hit it with square waves......more ringing than a cathedral bell.....
but I am somewhat surprised at the sheer SIZE of that motor, it looks huge, and even with aluminum windings....that's a lot of iron I can imagine the heat sink necessary to cool the main switch pass devices, assuming it's an a/c motor.....with a Variable Freq Oscillator to drive it....kinda like a PWM type thingy allmost.....
trying to dupe that in a home garage is allmost impossible, and certainly not cost effective.....UNLESS I wuld find a similar motor from someplace for cheeeep....from it's appearance it drives into a normal diffy...I can't see any other way to drive two wheel without one.....which is why I was thinking of my two golf cart motors...one on each wheel in the rear...NO diffy....
let the motor drag even it out...figger the amount of left/right turns will balance out.....:thumbs:
